Front passanger side rattling - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 08-17-2015, 11:43 PM Thread Starter
I hope someone has had this
So I've got a slight rattle when I hit manhole covers *I try to avoidthem* it's only the front passenger side I have replaced the following
Ball joints leafs shocks calipers steering stabilizer swaybar bushings endlinks
Everything else seams good and tight
Took to ford and they are stumped
I doesn't feel like a safety issue it's just drive me mental thx langley bc
Tmleafs is offline
post #2 of 15 (permalink) Old 08-18-2015, 02:19 AM
I like Fords Too's Avatar
hubcap ?
my 01 had a cap rattleing on a rear wheel because the socket clip thingys that grab the lug nuts were streached too much
a little squeeze with the channel lockes fixed that up
if you can rattle it by hand the bumps are sure to do it
I like Fords Too is offline
post #3 of 15 (permalink) Old 08-18-2015, 12:22 PM
Canadian Bacon's Avatar
What kind of vehicle? Has it been in an accident? What kind of rattle is it? Metal on metal?
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #4 of 15 (permalink) Old 08-18-2015, 03:52 PM
But was the work done at a "good white family shop" ?
post #5 of 15 (permalink) Old 08-18-2015, 09:29 PM
No, it wasn't done in my backyard.
post #6 of 15 (permalink) Old 08-22-2015, 10:34 AM Thread Starter
It's a 01 f250 Work done myself except the balljoints metal on metal almost sounds like a pop can with a rock in it
Tmleafs is offline
post #7 of 15 (permalink) Old 08-22-2015, 10:41 AM Thread Starter
No accident hub covers all tight
Tmleafs is offline
post #8 of 15 (permalink) Old 08-22-2015, 12:12 PM
calliper rattle ?
post #9 of 15 (permalink) Old 08-22-2015, 02:31 PM Thread Starter
Ok so after hrs off prying and smashing knuckles I found the problem. .
I can wiggle the passenger side axle up and down it creates the same noise I've been hearing now the question is?
Is the needle bearing shot I found a lot of videos on this on u tube but nobody says what the fix is?
Help pls
Thx
Tmleafs is offline
post #10 of 15 (permalink) Old 08-22-2015, 07:38 PM Thread Starter
Also is it drivable. I'm probably going to have this done at a shop when I can afford to.
Is this a hazard or can I drive?
Tmleafs is offline
95 step-side Sticky58 F-150 Pre-1997 Forum 5 02-07-2012 08:30 AM
Side Mirror TeamGreen F-150 2009 to 2014 Forum 5 07-15-2010 07:18 PM
Creaking sound from front drivers side wheel area. Ken24 Suspension 8 02-12-2010 06:16 PM
side exhaust heavyhitter Intake, Exhaust 2 12-12-2008 12:45 PM
Post 'em up Side by Side Bush_aholic Photo and Video Gallery - Members Rides 11 05-25-2008 08:06 AM
