### truck won't start - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 14Likes
  • 2 Post By I like Fords Too
  • 2 Post By CanadianRanger
  • 1 Post By Destructicon
  • 3 Post By Destructicon
  • 4 Post By I like Fords Too
post #1 of 6 (permalink) Old 04-21-2017, 12:42 PM Thread Starter
I like Fords Too's Avatar
so , it started out as a good day .. like it always does
went to the bank and paid the 4 dollar fee for starting a hwy 407 account - my plates got stolen off a car I had in storage & someone used them for a free hwy 407 ride
then I drove across the parking lot to canadian tire to get some cat food (yeah I think that sounds weird too)
came out thinkin' I was all done my errands .. but the truck , she no startie
I tryed tightening the negitive clamp - it was loose - had an issue with it last year
nope
tryed grinding the cable clamps and posts clean .. nope
at this point I was outta tryables , in canadian tire's parking lot , with no tools
so this is what it's doing
I turn the key and all I get is a thunk sound , no clicking , no indication of any load being pulled from the battery - the alt gauge dosen't budge when I try cranking it
soo , I'm thinking it's the relay box on the firewall that all the cables run to
I'd figure it would show a pull on the battery if it was the starter or soloniod and yes the battery seems to be fully charged as everything else works just fine
I did go under hood about a week ago with the hose to wash things out after the winter so hopefully it's just going to be a bad contact on the relay
at least that's going to be the first thing I try - cleaning the terminals and cable ends
and just my luck the oh so close wrecker's is closed as all their buildings burned down a couple of weeks back
Destructicon and SVT4MT like this.
I like Fords Too is offline
post #2 of 6 (permalink) Old 04-21-2017, 07:57 PM
That certainly is a not so great day. Hopefully it is something minor and simple like a bad contact or connector.
post #3 of 6 (permalink) Old 04-21-2017, 09:54 PM
Starter solenoid doesn't usually pull a lot of current. So are you getting the appropriate thunk or just a click?
SVT4MT likes this.
post #4 of 6 (permalink) Old 04-21-2017, 11:34 PM Thread Starter
one thunk per start try
no click or clicking , just thunk ..
post #5 of 6 (permalink) Old 04-22-2017, 06:25 AM
Try tightening the starter bolts. Not too much. Just enough to clean the oxides off between the starter and the bellhousing. 1/8~1/4 turn. If it starts then you know what the problem is which is very typical. If not, use a booster cable from the battery negative to the starter casing. If any or all of this gets you started then run a tap through the starter mount bolts and upgrade by putting a large ground cable to the starter casing. The steel part not the aluminum part. I've yet to see a Ford that isn't repaired by this method usually permanently. If none of that works, you're probably in for a starter replacement.
CanadianRanger, SVT4MT and Mrmagoo like this.
post #6 of 6 (permalink) Old 05-04-2017, 02:10 PM Thread Starter
I was sure it was a connection someplace .. I jus knewit
turns out the terminal on the end of the positive cable down at the starter was rotted compleately off
gotta go to crappy tire this eve and scooop a new crimp on terminal and I should be good to go
NEED HELP: Truck won't start meecraw Ranger Forum 10 08-23-2011 09:41 PM
NEED HELP: ASAP-truck won't start Arctic F-150 F-150 2004 to 2008 Forum 11 11-25-2010 12:27 AM
Remote start won't start MrSen F-150 2004 to 2008 Forum 8 12-04-2009 07:58 PM
HELP! truck won't start! lightning25 Gas Engines 14 01-18-2009 03:03 PM
NEED HELP: truck won,t start mackmanken F-150 2004 to 2008 Forum 15 10-13-2008 10:17 PM
