NEED HELP: F150 parts - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 1Likes
post #1 of 15 (permalink) Old 04-24-2017, 11:15 AM Thread Starter
F150 parts
I need a new steering shaft and I am wondering if anyone has any recommendations on where to buy it. Thx
Deerlake is offline
post #2 of 15 (permalink) Old 04-24-2017, 06:11 PM
Salvage yard? Why do you need a new steering shaft? BTW - Welcome to the site.
CanadianRanger likes this.
post #3 of 15 (permalink) Old 04-24-2017, 08:52 PM Thread Starter
Thanks. My steering is so stiff it is driving like a truck lol. I want a new shaft, not one like I already have.
Deerlake is offline
post #4 of 15 (permalink) Old 04-25-2017, 05:26 AM
Everything else has been checked? Steering linkages, ball joints, power steering pump, power steering rack/box, CV joints/u-joints, tires/tire pressure? Alignment?
post #5 of 15 (permalink) Old 04-25-2017, 06:42 AM Thread Starter
Those are all potential problems, I have checked everything you mentioned except the ball joints. I guess I will do that today. If I spray WD40 on the ujoints for the steering shaft the problem disappears. Evidently this is not uncommon for a F150. Is that logical?
Deerlake is offline
post #6 of 15 (permalink) Old 04-25-2017, 07:04 PM
Ok. WD40 strips all of the grease out and temporarily lubricates. Can you just change the u-joints in these? You could in the older ones.
post #7 of 15 (permalink) Old 04-28-2017, 09:46 AM Thread Starter
I sure wish I could. They make it so you have to replace the whole shaft. Even better would be a grease nipple.
Deerlake is offline
post #8 of 15 (permalink) Old 04-28-2017, 04:18 PM
Time to upgrade to some good old fashion technology.
post #9 of 15 (permalink) Old 04-29-2017, 05:12 PM Thread Starter
ya you said it. it's funny because when you buy a vehicle you have no idea what kind of shortcuts they have made with the design. So I checked my ball joints and the upper driver side one is a bit clicky. It turns out that for a 2010 the ball joints are incorporated right into the control arm. Funny because the dealer mechanic told me that I needed a new control arm but never said it was because the ball joint needed to be replaced. I would love to find a better place to buy parts than Ford or Canadian Tire / Partsource. I don't think this will have anything to do with the stiff steering but it still needs to be addressed.
Deerlake is offline
post #10 of 15 (permalink) Old 04-30-2017, 12:08 PM
I like Fords Too's Avatar
yeah it probably has everything to do with the stiff steering
my 01 meeded ball joints
it required a definate effort to turn it and if that turn was a sudden reaction to something in front of me the steering was stiff enough that I'd have to be committed to the reaction as the counter steer back from the reaction was going to be really really slow
3 new ball joints solved the issue compleately
the control arms are usually made as an assembely these days in many vehicles
the ball joints are often now pressed into the control arm and spot welded into place instead of being threaded into a socket in the control arm
cheeper to make and maybe , maybe easier to install with simple tools
bonus is you get new control arm bushings too
I like Fords Too is offline
