NEED HELP: Water leak - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
 1Likes
  • 1 Post By macs07
post #1 of 5 (permalink) Old 05-05-2017, 08:34 AM Thread Starter
macs07's Avatar
Water leak
getting a leak from the P/S grab bar in my 2013 FX4. I googled it and found reports on the leak may originate from the Sat mount on the roof or the third brake light.
Anyone had an exp with this??
macs07 is offline
post #2 of 5 (permalink) Old 05-05-2017, 03:12 PM
Seems to me a few years ago some of the guys were having trouble with this and turned out
to be leaking around the high mount brake light.
post #3 of 5 (permalink) Old 05-05-2017, 04:50 PM
In the past, I've sealed the third brake light with clear silicone, does the trick nicely.
No issues currently, so haven't bothered yet, but its easy to do , you'll never see it and its not a bad idea, the seal on those third brake lights could use some work.
post #4 of 5 (permalink) Old 05-06-2017, 04:51 PM Thread Starter
macs07's Avatar
Water Leak
Turns out it was a leak from the sat mount on the roof over the windshield. Not only was it coming out of the grab bar bu also running along the roof liner and down the inside of the back window.
removed the sat mount there are 2 gaskets an outer with a hole for water to escape at the front and an inter to protect the cercets and stop water from getting in through the fastener area. Reworked both seals. Thanks for your help.:smile2:
Mrmagoo likes this.
macs07 is offline
post #5 of 5 (permalink) Old 05-08-2017, 08:50 PM
ya I had the same problem from the P/S grab bar and then from the third brake light. I have never had a vehicle do that before. I guess Ford Quality is number 1. lol
Deerlake is offline
Third Brake Light Water Leak Armen Exterior 5 12-16-2010 09:43 PM
WATER LEAK Blaizz F-150 1997 to 2003 /04 Heritage Forum 1 03-16-2010 12:45 AM
Water Leak!! Cooker Ranger Forum 10 11-24-2008 03:02 AM
Water leak by drivers side kickpanel??? LUVMYSUPERDUTY Super Duty Forum 13 06-21-2008 05:51 AM
Water Leak bat052 F-150 2004 to 2008 Forum 2 11-26-2007 07:35 PM
