Under the f150 hood - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 05-22-2016, 10:33 PM Thread Starter
Under the f150 hood
Does anyone have a diagram or something about what all the crap is under the hood. Seems to be emissions gear mostly on the passenger side. Or I guess what can a remove without sending codes , or something
1995 f150 5.8. 351w 4X4
Cheers
Ujoint is offline
post #2 of 3 (permalink) Old 05-23-2016, 08:23 AM
It's not carburated. There's not a whole lot to remove without screwing up the injection computer. If it's power or gas milage you're looking for then consider using a programmer to retune the computer, cool air intake, more efficient exhaust system, throttle body spacer,... Etc. The air pump is about the only thing you want to get rid of but reprogram the computer so it doesn't sense the solenoids missing and for better fuel mixture/ratio. Get rid of the clutch fan and go electric fans. Use synthetic oil in the diffs. Better spark plugs. I use v groove plugs. Seal up vacuum leaks, especially the injector o rings that everyone forgets. Changing intakes and heads is for more advanced HP increases and get quite costly. Camshafts and of the like, might as well rebuild the engine and prepare to free up $10k for a really good job. Using a traction lock rear diff helped my milage. No more one wheel peels in bad weather. Lighter foot on the throttle. Use cruise control. Clean air filters. Regular oil changes. Check your compression to see if your engine is tired or not. If you have an automatic transmission, consider retuning for better shifting or convert to standard. You can do a whole bunch of stuff, but if you start ripping out vacuum lines and wiring, you'll have a dead truck in minutes.
post #3 of 3 (permalink) Old 05-25-2016, 03:41 PM
Something.
NEED HELP: re hood ornament ????? finding41 Exterior 2 06-30-2010 11:14 PM
Hood scoop gewiens Raptor, Harley-Davidson, Limited, King Ranch, 60th Anniversary, Platinum 18 12-03-2009 12:24 AM
hood mods shelbyx1 Exterior 12 03-08-2009 12:09 AM
Shaker Hood? Roadwarrior F-150 2004 to 2008 Forum 2 01-22-2008 07:50 PM
