D Ring Shackle - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 12-31-2015, 05:57 PM Thread Starter
James066's Avatar
D Ring Shackle
Picked up a couple coated 3/4" 6 and 1/2 ton shackles with 7/8 pin the other day. Gonna be used in my receiver block. Just wondering from the avid offroaders here if these will be strong enough for a half ton on half ton recovery in mud or snow. They will be attached to a 3"x30' Rugged Ridge recovery strap.
2012 FX4 3.5L Ecoboost Silver
James066 is offline
post #2 of 8 (permalink) Old 12-31-2015, 06:02 PM
What's the strap rated for?
post #3 of 8 (permalink) Old 12-31-2015, 06:15 PM
Whats offroad?
post #4 of 8 (permalink) Old 12-31-2015, 08:46 PM
TRNRBILT's Avatar
They've never let me down. I have two on the tow hooks so its easier to mount the strap to it. Used them to pull my 150 and my uncle's 250 4x4 4 door diesel so you wont have to worry about the shackles. Strap will be the weak point.
TRNRBILT is offline
post #5 of 8 (permalink) Old 01-01-2016, 01:32 AM Thread Starter
James066's Avatar
Recovery strap claims it's rated for 30,000lbs
James066 is offline
post #6 of 8 (permalink) Old 01-01-2016, 08:45 AM
Then I'd say your good for 6.5 tons, safely.
post #7 of 8 (permalink) Old 01-01-2016, 01:28 PM Thread Starter
James066's Avatar
Yea.....I'm used to holding 30 ton LAV shackles in my hand and this 6 1/2 ton one just looks so small lol. Thought I'd check.
James066 is offline
post #8 of 8 (permalink) Old 01-24-2016, 10:12 AM
is it a recovery strap or one designed for hoisting ? the hoisting one while strong wont stretch enough to take a shock load of a recovery and will break if trying to snatch a vehicle... one designed as a recovery strap will stretch like an elastic band and works 10x better.
Shackles should be good but if they aren't name brand (ie Crosby) or have the load rating on them then avoid them... a lot of crap from over seas that in no way passes a load test and fails way before a reg rating.
Differental Ring Gear size deadeye1 F-150 1997 to 2003 /04 Heritage Forum 3 09-26-2011 10:12 AM
oil drain plug washer or O ring? sunflower F-150 2004 to 2008 Forum 1 09-29-2010 11:25 PM
How to: Rear Axle and Pinion Seal replacement (7.5 ring gear) jdcrush Ranger Forum 8 08-22-2010 02:56 PM
Lift Shackle herbz Suspension 3 02-24-2010 10:16 AM
Drop Shackle questions? f150phule Suspension 2 06-17-2009 12:20 AM
