NEED HELP: Engine compatibility - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 03-03-2012, 02:11 AM Thread Starter
Hey everyone. I recently started giving my truck an overhaul and I'm having a hard time finding an engine. I was wondering if anyone could give me some advice on what will fit? I have a 1990 f-150 lariat XLT 4x4 V8 automatic with a 5.0L 302... Any idea how many model years newer that I could go with an engine?
zack is offline
post #2 of 15 (permalink) Old 03-03-2012, 07:32 AM
I just did search on the auto wreckers site. found replacement engines 1987-1993.
www.car-part.com
post #3 of 15 (permalink) Old 03-03-2012, 07:32 AM
You could go up to 93 without any issues. In 94 the firing order changed to the 351 order so you could also use a 94 95 motor as well but you'd have to swap some plug wires around. If you grab a 96 motor you're gonna have to change every sensor cause in 96 they switched over to OBD2
post #4 of 15 (permalink) Old 03-03-2012, 12:03 PM
From what I've gleaned out of the '95 so far, you should be able to go back to the early 70's or even further. From a bolt pattern point of view. Inline 6, 289, 302, and 351W, 3.8 V6 may bolt up, too. Depends on what you want, carburated, fuel injected, or propane/natural gas. Oil pans and sumps are a bit of an issue. Being front, back or double.
post #5 of 15 (permalink) Old 03-03-2012, 06:14 PM
Ol Skool's Avatar
1968 to 1996, The 302 or 5.0 were like SBC's (only better) Each year would interchange. 351W/C will fit right in where a 302 came out of. It ain't rocket science. I've been playing with Small Block Fords for years. My next project is a 62 unibody, with a 4.6 Roush with a 6 speed box. Starting in the spring. I needed something to keep me off the streets.
Gerry
Oh yea....The 289 (1964 to1967) will fall in there to.
Ol Skool is offline
post #6 of 15 (permalink) Old 03-03-2012, 06:30 PM
Gerry
Hey Gerry, is that going to be a short box?
post #7 of 15 (permalink) Old 03-03-2012, 11:30 PM
Ol Skool's Avatar
Ofcourse, I bought the truck last fall. It's semi good. And some idot put a 396 in it. I have it in storage at the moment. I will start a posting with pictures as I progress. At this time, I'm gathering parts, slowly.
Gerry
Ol Skool is offline
post #8 of 15 (permalink) Old 03-04-2012, 12:06 AM
Supposedly there's a compamy in the states that manufactures Ford truck body's of any year to fit whatever frame you have for $4000 complete
post #9 of 15 (permalink) Old 03-04-2012, 10:42 AM
Of ANY year? I'd be wary of anything for that price. I'm a regular reader of Classic Trucks/Custom Classic Trucks and there's ads in them for cabs for 48-56 F-100s for around $4k.
chrmar is offline
post #10 of 15 (permalink) Old 03-04-2012, 06:48 PM
Ol Skool's Avatar
Even that seems cheap. One of my friends owns Pro-pick, a large supplier of F100 parts in Canada. He still searches for good southern cabs. If they were that cheap, I'm sure He would let me know. But I will check with him. Because, If they make it for 1948 to 1979 F100's, George knows about it.
Gerry
Ol Skool is offline
engine 4.6 gilligan F-150 1997 to 2003 /04 Heritage Forum 11 08-10-2014 07:07 PM
4.0L Engine? FX4Ranger Gas Engines 0 12-16-2010 03:37 PM
NEED HELP: rim compatibility? tank_dean Wheels and Tires 3 07-05-2010 09:38 PM
uh oh.. engine knock? camkos Ranger Forum 2 05-05-2010 10:40 AM
'06 5.4 engine too hot? nagles06 F-150 2004 to 2008 Forum 5 04-22-2009 09:09 PM
