gas to diesel - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 02-22-2009, 08:38 PM Thread Starter
gas to diesel
hi,can someone tell me if i have to have my truck inspected after installing a diesel into it,the truck it's going into is a 87 single cab long box and the diesel is from a 89 extended cab both are 4x4,thanx for any replies.
89 f250 4x4(diesel) 92 explorer
If everything seem like it's under control, you're just not going fast enough. -Andretti
What's the point if you can't wrap it around a tree?
northernlights is offline
post #2 of 7 (permalink) Old 02-22-2009, 08:42 PM
Stainless's Avatar
I have never ran into that before, if you have emmisions testing where you are( not sure where Stewart is) you may have to.
Stainless is offline
post #3 of 7 (permalink) Old 02-22-2009, 09:05 PM
One rule i've heard is that the engine going in must be of the same year or newer...but this could only apply to the states. i did a quick search and couldn't find anything on B.C.'s laws in that subject. hopefully this swap won't go for not...if you can't register/get insurance for it. Good luck.
post #4 of 7 (permalink) Old 02-22-2009, 09:31 PM Thread Starter
thanx for the reply stainless,i don't think i should have any problem then there's no emmisions law in northwestern b.c. as far as i know and if it did i don't think i would have any problem if i transfer everything over from the diesel truck,the only reason i'm doing this switch is that the exteded cabs frame is completly rotted through at the back end and the single cab frame is in much better shape except the cab is in need of a little repair,i was just curious about going to get insurence cause the engine type is going to different then the previous owner.
post #5 of 7 (permalink) Old 02-22-2009, 09:38 PM Thread Starter
thanx for your reply northern supercrew,you live not to far from me i go up to whitehorse alot have family there,as i stated in my last post i shouldn't have any problem unless i move out of b.c. and have to get it inspected.
post #6 of 7 (permalink) Old 02-25-2009, 01:46 PM
canadian.bacon's Avatar
as long as the engine is newer then the vehicle and you have all appropriate emissions equipment there isn't much problem in ontario anyways. if you require an emissions test down the road you can have it tested as a hot rod vehicle as well, which gives it much more lax limits to hit. thats how i passed my old 2.5L civic!
canadian.bacon is offline
post #7 of 7 (permalink) Old 02-25-2009, 02:44 PM
Not sure if the frames are much different between gas and diesel trucks...if your interested I have a frame from an '86 diesel F-250 (reg cab, long box). You just have to come and pick it up...no charge.
Gas Mileage lynger F-150 Pre-1997 Forum 15 04-16-2010 08:38 PM
Gas? Silver FX4 Truck/SUV Talk 13 08-08-2008 09:20 AM
