Need Help in choosing a good truck - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 08-01-2009, 12:38 AM Thread Starter
I was hoping to ask the ford gurus in this forum regarding the good and the bad, pros and cons of the F 150. I was planning on getting one soon. I found a 97 /ext cab /4x4 /5.4 /v8 /316,946k/ no rust/ auto / cloth int. power windows and door locks etc... for $4500. There is another one I was looking at 97 /4.6/ v8/ 260,000k/ slight rust at left rear bumper/auto/ leather/ power windows and door locks etc../4x4/ ext cab /one of the rims is different from the three stock F150 rims for $3500. And my last choice was a 98 250,000k/ext cab/ 4x2/ v6/ no power options/ one of the rear right wheel stud is broken/ a few scratches/ no rust/cloth int for $3000. is 316k too high for a 97 and is it over priced? What should I watch out for? Please any recommendations is greatly appreciated.
drin05 is offline
post #2 of 10 (permalink) Old 08-01-2009, 01:46 PM
I would probably pick the 97 with the 4.6...just for the fact of the lower mileage..If you only tow occasionally, you'll probably enjoy that motor. That series of trucks had a problem of the sparkplugs occasionally blowing out of the head...but that applied to the 5.4 also. The little rust wouldn't bother me at all..neither would the different rim..could pick up a match on Kijiji. I had a 97 with the 4.6 and put on 170,000 k's when traded off. Nothing major ever broke. Could get 19-20 on the highway with the stock tires..but down to 16 when 265-75-16's were installed...and down to 14 when -40 hit.
post #3 of 10 (permalink) Old 08-01-2009, 05:39 PM Thread Starter
Thanks for the input.
drin05 is offline
post #4 of 10 (permalink) Old 08-03-2009, 12:27 AM
Just avoid any 97 4.2l or an early 98 4.2l (built in January '98). They had an issue with bad gaskets that led to hydrolocked motors.
post #5 of 10 (permalink) Old 08-03-2009, 12:44 AM Thread Starter
Thanks for the input.. Is the v6 better than the v8?
drin05 is offline
post #6 of 10 (permalink) Old 08-03-2009, 01:44 AM
depends on what you plan on using the truck for
post #7 of 10 (permalink) Old 08-03-2009, 10:32 PM Thread Starter
occasional towing bikes and or atv. usually travelling around the city.
drin05 is offline
post #8 of 10 (permalink) Old 08-04-2009, 10:21 PM
invest in the 4.6 its a more common engine and parts are galore if it craps out on you
i had a v6 briefly in a reg cab shortbox 2wd and it was a POS bad on fuel (no better then a 5.4L 4x4 ext cab) they had issues.
early f150's (of above years) also had issues with pitman arms and rust on the bottoms of the doors/tailgate and a cracking door (about shoulder height drivers side mostly) and the 9.75 rear ends had issues with the limeted slip clutch packs
sounds like alot of negitive but most would have been fixed under a recal or TSB to the orig owners
post #9 of 10 (permalink) Old 08-06-2009, 10:53 AM Thread Starter
What should I be checking for and inspecting for a truck that has high mileage. signs of abuse ?
drin05 is offline
post #10 of 10 (permalink) Old 08-06-2009, 03:09 PM
the best thing to get on a high milage vehicle is service history,it will help decide if it was cared for,also the 97-2000 triton engines had issues with not enough threads for spark plugs causing them to blow out of the heads,and oil leaks at rh rear of engine.
Is this any good? Rustycan Ranger Forum 7 12-19-2008 03:09 PM
I clay bar'd my truck and it didn't turn out good Duty calls Photo and Video Gallery - Members Rides 10 06-17-2008 07:25 PM
Help choosing a tuner leonard Programmers and Tunes 14 06-10-2008 07:44 PM
Good truck shop in Ottawa??? truckpilot Ontario 10 01-30-2008 12:24 AM
