clutch starter switch - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 11-30-2009, 11:43 PM Thread Starter
I bought a 1997 f 350 with a standard transmission and I had to push the clutch to the floor as hard as I could and even then it would just start. So I had a look under the dash and noticed a gap between the pedal pivot pin and the push rod on the clutch slave. The plastic shim was worn out I would think that this is a fairly common problem with these trucks. I replaced the plastic shim that was worn out with a piece of 1/2 inch copper pipe that I had laying around the shop it fit perfectly. Cut about 1/4 inch piece grease it on both inside and outside and it fit great. Then I put a cotter clip on the end of the pin to keep the new shim in place. Now I don't get anywhere near the floor board before it turns over. A cheap fix to a common problem and the safety switch doesn't have to be disconnected. dave
1tonne is offline
Clutch Pedal Adjust Billy Mo F-150 Pre-1997 Forum 5 12-01-2009 11:08 PM
Remote starter brauner_1 Audio and Electronics 1 12-16-2008 03:35 PM
Remote starter, who has one? fordtough.ca Truck/SUV Talk 12 09-27-2008 02:20 PM
starter help Frumpy Gas Engines 5 05-27-2008 10:26 PM
