spacers or keys??? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 03-30-2010, 02:00 PM Thread Starter
01f150's Avatar
spacers or keys???
Just wondering what you all think is best for about 2 to 2 1/2inches of lift.(I'll use blocks in the back) Spacers or keys for the front??
01f150 is offline
post #2 of 5 (permalink) Old 03-30-2010, 03:17 PM
Being an 01' and a 4x4 you have to use keys in the front because you don't have coil springs. Spacers are for trucks with coil springs in the front like the 04+ trucks.
post #3 of 5 (permalink) Old 03-30-2010, 03:42 PM
i haven't heard much good of useing indexed keys in the front,they put your axles at too axtreme an angle and put too much load on the torsion bars.
post #4 of 5 (permalink) Old 03-31-2010, 01:58 AM
I would stay away from indexed keys on all they do is cause a extreme angle's causing your CV' boots to tear and the CV's wear faster and ball joints to wear faster, if you want a couple of inches higher from the front of your truck just crank the torsion bars a little no reason you shouldn't be able to get about 1 1/2 inch raise from it and don't forget to get an alignment when your done
post #5 of 5 (permalink) Old 03-31-2010, 03:12 PM Thread Starter
01f150's Avatar
thx for the replys....
01f150 is offline
Wheel spacers mechanix61 Super Duty Forum 2 03-21-2010 12:16 PM
torsion bar keys? 09'FX4 Off Road 12 03-04-2010 05:36 PM
2 inch wheel spacers sodapop F-150 2004 to 2008 Forum 4 03-26-2009 11:31 AM
Throttle body spacers ??? Limited Randy F-150 2004 to 2008 Forum 7 04-24-2008 05:43 PM
