Winter prep.. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 10-19-2011, 09:45 AM Thread Starter
Winter prep..
Hi , Just bought my truck,and I'm wondering how the stock 18" Goodyear Wranglers are in snow ?? Also should I put some sandbags in the empty bed for better traction ??
I've always used snow tires on my cars.I'm wondering if I should get some for the truck.I'm guessing 18" snow tires are not cheap!
2011 F150 FX4 SCREW
Biggles is offline
post #2 of 5 (permalink) Old 10-19-2011, 01:06 PM
Sandbags are recommended by many. I typically put 250-300 pounds in my Ranger.
I bought my Ranger in late Dec 2009 and drove the remainder of the winter in the stock Wranglers. Nothing special that I had noted. Had ordered winters when I bought my truck (not easy to find winter tires in late Dec/early Jan), but didn't have them installed until the following winter. It was over $1200 for a set of 16 inch Ford steel rims and four studded General Altimax Arctic winter tires. Probably could have saved another $100-$200 if I had ordered generic steel rims....but I didn't want any fitment or vibration issues.
I would check around to see if you can downsize to a 17 inch...or even a 16 inch (rears are disc brakes?). What's your stock tire size? LT- or P-rated winters?
Dave
2010 Ford Ranger FX4
DavidY is offline
post #3 of 5 (permalink) Old 10-19-2011, 04:59 PM Thread Starter
Thanks for your reply.
Rears are discs . Stock tires are P rated.I'll try adding some sand bags and see how things go.Meantime I'll start saving for some winters,just in case I need them!
Biggles is offline
post #4 of 5 (permalink) Old 10-19-2011, 06:47 PM
The following URL gives you a rough idea on the cost of winter tires plus steel wheels for the F150...prices are in Toronto:
http://www.simplytire.com/winter/fordpdf.pdf
245/70-17 are 4.9% smaller than stock (assume stock is 275/65-18). I think that either 245/75-17 (-1.9%), 255/75-17 (-0.1%), 265/70-17 (-1.5%) would be a better fit....load rating differences would be less too...stock load rating is 114. 245/70-17 is 108. 245/75-17 is 110. 255/75-17 is 113. 265/70-17 is 115. I would check that your brake calipers will clear a 17 inch wheel (likely...but you don't want to find later that it doesn't).
I would definitely budget at least $200 per winter tire plus $100 for 17 inch steel wheels. Balancing, studs if desired, mounting, taxes, levies or eco fees would likely be extra. I would assume that you would want skip the TPMS sensors....I did since I don't mind the idiot light every so often....no need to calibrate the TPMS twice a year (with two different sets of TPMS sensors). I think that TPMS sensors are around $200 per set of four (another thread at this forum).
Dave
DavidY is offline
post #5 of 5 (permalink) Old 05-09-2012, 12:23 AM Thread Starter
Winter was a non event. The stock tires fine.I didn't use any sand bags.
But it was a mild winter without much snow in Calgary.
2011 F150 Supercrew FX4
Biggles is offline
Winter Programmer johnnyo888 Programmers and Tunes 5 03-11-2009 08:06 AM
Winter shoes fordtough.ca Truck/SUV Talk 13 11-12-2008 04:35 PM
NEED HELP: Winter Weight Writerz Block Ranger Forum 31 11-08-2008 04:56 PM
