Speedo reset - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 10-24-2011, 10:06 PM Thread Starter
Speedo reset
Hi guys,
I've been lurking around here and other F150 forums for a bit, bought a 09 SC XLT couple years ago, been a great truck but I made the mistake of getting the hancook tires with it, I bought used a pair of michelin x-ice for the winter on steel rims, this has done me well for 2 years but now need replacing. I figure if Im going to replace them I might as well get bigger rims, looking at the monster or rockstar rims if I can find them, along with toyo or MT tires, 33 inch in around there. My issue is I would like the speedo to be reading proper. What are guys doing for this? SCT tuners? any other options?
Thanks for the help.
Bruce
T1bird is offline
post #2 of 6 (permalink) Old 10-24-2011, 10:47 PM
Superchips personally
post #3 of 6 (permalink) Old 10-24-2011, 10:59 PM
If you are going to spend the money on the programmer you might as well get some custom tunes like a custom SCT X-Cal 3 or Gryphon (Edge). Your local Ford dealer can also reflash your ECM for you for a fraction of the cost of the programmer for the larger tires.
post #4 of 6 (permalink) Old 10-25-2011, 08:44 PM
I have larger tires on my truck and I bought a sct x3 and changed the speedo I'm also running the truck on the 87 tune
post #5 of 6 (permalink) Old 10-26-2011, 08:57 PM
id get a programer as well sct superchip edge dibiablo sport all are good
post #6 of 6 (permalink) Old 10-30-2011, 09:37 PM
glufactory5.4's Avatar
your dealer can do it if its a valid tire size option in their laptop software,IF you do chose to reflash your pcm (power programmer ) beware if you have any warranty left consider the fact they may not cover whatever breaks (ford or aftermarket warranty) they now know when non-factory reflash has been done.they can and will deny repairs based on whatever is found.that being said I run sct pro racer pkg without problems.
-2003 F-150 5.4 4X2 SHORTBOX STEPSIDE
-HEAVILY MODIFIED
glufactory5.4 is offline
tpms reset tool benyl F-150 2009 to 2014 Forum 5 12-20-2010 06:38 PM
simple question, oil change reset age Gas Engines 10 11-14-2010 10:53 PM
NEED HELP: Changing speedo gear on 97 f150 f150phule Driveline and Transmission 4 10-20-2009 01:29 AM
Speedo gear help SKRWZ Wheels and Tires 0 12-10-2007 01:00 AM
