Don't check /scan for codes before drive clean test.. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 05-06-2014, 12:47 PM Thread Starter
I like Fords Too's Avatar
3 months I've been driveing my truck with the tune set back to stock because I knew I had to do a drive clean test this spring
today I took it in - right after checking for any codes that might fail it with their new check codes d-c test
well low and behold I didn't fail ... but I also didn't pass
what the hell...
computer had no data to provide for the drive clean test with regards to a couple of items
evaperative system - not ready
egr system not ready
what to do ? - according to a little hand out form the province :
step 1 -make sure the vehicle has been parked at least 8 hours without starting
step2 - start engine and let it idle in drive for 2 1/2 minutes with the airconditioning and rear defrost on
step 3 - turn a/c & defrost off & drive at highway speed for 10 min
step 4 - drive in stop & go traffic for 20 min
step 5 go back and try again - but this must be no less than 24 hours after the preceeding test
if your vehicle has multiple readyness failures it may be issued a "readyness conditional pass"
this may be used for registration renewal
if 24 hours has past between tests
if vehicle has been driven at least 30 km between tests
battery has not been disconnected and OBD codes have not been cleared in the last 30 km
number of not ready issues is not more than the number occuring in the preceeding test
if these conditions are met you can be issued a readyness conditional pass
but if your selling / buying the car it still has to pass a tail pipe sniff test
this info is straight from the papers the drive clean test / province give you when the test comes back - not ready
at least the place I went to didn't charge for the first try
I like Fords Too is offline
post #2 of 9 (permalink) Old 05-06-2014, 01:02 PM
Glad we don't that crap out here.
post #3 of 9 (permalink) Old 05-06-2014, 02:57 PM
Canadian Bacon's Avatar
Why did you put it back to stock with your programmer? The Lightning passed and I didn't change shit.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
post #4 of 9 (permalink) Old 05-06-2014, 03:02 PM
true dat. although there are some pretty shitty vehicles on the road that would be removed if testing happened which would be a good thing.
i get a photo radar ticket for speeding but farmer joe can drive his 1973 pos rusting apart and if it needed to stop quicky the frame would probably stop and the body keep going.
post #5 of 9 (permalink) Old 05-07-2014, 02:47 AM
what to do ?
Stop voting for enviro-commies.
post #6 of 9 (permalink) Old 05-07-2014, 02:58 AM
That problem will take care of itself eventually.
On the other hand, how much pollution do you think every person in the city with a barbeque or friggin' fire pit belches into the air? In the city, no less.
Photo radar is just an Edmonton cash-cow. It's never going away.
post #7 of 9 (permalink) Old 05-07-2014, 07:13 AM
For that matter, what about natural gas funaces and water heaters. Fear not, for Alberta will be e-tested soon enough.
post #8 of 9 (permalink) Old 05-07-2014, 04:13 PM Thread Starter
ya I guess I polute
11-1200 bucks worth of heating oil each month this past year
tank's empty now I refuse to fill it again for the time being - a couple of heaters will keep the space I use warm
- 180-200 is hst
BONUS .....I get ripped of 'cause I don wanna freeze to death
post #9 of 9 (permalink) Old 05-08-2014, 03:56 PM Thread Starter
I didn't want to chance the fail
took it back today - passed with no issues so I went and got my plates renewed
here our sticker goes on the front plate if it's a truck
well , I ripped off the plate and the plastic piece that hangs from the bumper last january on a pile of frozen slush- so I've had no front plate since
it was a little iffy driveing it with no front plate after and expired tags to boot
but MAYBE this afternoon I'll go out and put my harley truck front facia on and replace the plate with it's new sticker - and bump the tune back up
Codes??? How to check? Arctic F-150 F-150 2004 to 2008 Forum 3 04-12-2009 11:44 PM
Check Engine but no codes? truckguy94 F-150 Pre-1997 Forum 23 09-06-2008 04:36 PM
