70's box switch - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
FordTough.ca Site Help? Problems, Related questions, comments, or suggestions only.
post #1 of 6 (permalink) Old 07-28-2015, 11:17 PM Thread Starter
70's box switch
Hello people, I have an almost mint 77 long box with the cargo compartment, what I need to know is the issues I will run into when I put this on my 78 chassis. I needed to replace the filler tubes as they where cut off, I,m assuming the gas tanks didn't change, so the filler tubes should work?, with the box being a 77 I'm going to change the grill to a 77 as well so it'll look correct. Can't wait to close my tailgate, with out having to push the box sides over! Yes I said sides.
cariboofordguy is offline
post #2 of 6 (permalink) Old 07-29-2015, 12:54 AM
Wheelbase match?
post #3 of 6 (permalink) Old 07-29-2015, 02:47 AM
if you are changing the bed from a 77 F250>78 F250 2wd, no worries. 150 2wd no worries.
if you are doing it on a 4wd F250, you might have some issues as 1977 was a big change year, early 77 had a divorce mount Tcase and a narrow frame ,late 1977 production went to wide rear frame like the 2wd F250 and same rear tank. other changes too but you are just changing a box.......
easiest way is to measure your box bolt holes R side to L side. if they are the same all the way back and both boxes match, you have it made.
I like the 77 grille better too, always wished they would have built early 78 broncos with that grille.
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #4 of 6 (permalink) Old 07-30-2015, 12:10 PM Thread Starter
70's box switch 2
Thanks for the heads up on the box bolts, I'll measure them first. Pretty sure the old box won't make another winter !
post #5 of 6 (permalink) Old 07-31-2015, 02:53 AM
we had a 1977 F250 that was collapsing at the back but the crossmembers underneath were still intact. we welded up some L channel along the top and rear of the box floor, then used the same metal for both upright tear posts . welded the corners together, after making sure it was square and tailgate still worked. then we used a triangular plate to brace the two together right where the 90 in the L was and it lasted 3 yrs until the sides basically rotted off the box. it really made it last, and we worked the truck on the farm and hauling scrap occasionally. this was a few years ago now> Ontario......................
[SIGPIC]
post #6 of 6 (permalink) Old 07-31-2015, 04:39 PM
zip
zip's Avatar
A little off topic but I grew up in Williams Lake. Ok carry on with the original topic.
Chris
75 F150, 79 Bronco
zip is offline
Upliffter switch led Iceman-Brett Exterior 4 09-11-2014 08:00 AM
common switch cdnarmyguy F-150 1997 to 2003 /04 Heritage Forum 2 11-30-2011 11:31 AM
Broken Window switch murray99 Sticky Tech/How to Section 5 05-19-2011 10:12 PM
Thinking about by passing switch Mar Ranger Forum 14 04-01-2011 10:36 PM
clutch starter switch 1tonne Truck/SUV Talk 0 12-01-2009 12:43 AM
