? powerstroke - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 10-07-2012, 12:43 AM Thread Starter
? powerstroke
not sure ,i just bought a 7.3direct injection turbo its a 94 250 xlt is this powerstroke?
mregan is offline
post #2 of 8 (permalink) Old 10-07-2012, 01:33 AM
'93-94 was the period when Ford was changing over from the IDI (Indirect injection) to the Powerstroke. And somewhere in between, there was IDI with turbo. I'm not totally sure when Powerstroke actually started ('94 1/2 or '95 I think). I'm not knocking this site, but there isn't a lot of diesel info here...especially the older ones. I'm a diesel guy and have been a member here for a few years now and I will be staying because there is a lot of good info and cool people here. If you can't get info you need here, go to: thedieselstop.com (I am a member there too). It's the best site for any Ford diesel and you should be able to find the info you're looking for. Good luck with your new ride, and keep us posted here with your progress so we can get more diesel info on this site.
post #3 of 8 (permalink) Old 10-07-2012, 01:41 AM Thread Starter
cool ill check that site out ...thanks
mregan is offline
post #4 of 8 (permalink) Old 10-07-2012, 02:00 AM
Yup most of the trucks on here are gassers and there's not a lot of pre97 owners here either. I'm one of the few but mine's a gasser
post #5 of 8 (permalink) Old 10-07-2012, 11:05 PM
In 1994 if you got a manual trans, it was a powerstroke, if its an automatic it came with an IDI turbo.
it is actually very easy to tell the difference by opening the hood:
powerstroke has the air filter on the driver's side inner fender.
powerstroke has no steel lines or injection pump on top of engine
powertroke has a fuel filter housing sitting right in the centre of the motor.
IDI turbo has a square air filter box in the centre of the engine with a hose going to same place the older 7.3 IDI n/a engines did.
your oil fill will be in a front timing cover(rounded aluminum thing), injection pump is mounted in this cover also, 8 steel lines running to all 8 injectors right on top.
fuel filter/housing is on top of the passenger side rocker cover.
I'm a diesel guy and have owned driven both of these engines.
both have their good points.
love the IDI turbo engine for its "off idle" torque, the turbo only pushes a little boost.
the powerstroke is a good motor, but not quite as good the first year as they used the EEC4 computer system. 95 -2003 were much easier to communicate with/diagnose problems.
for low speed/offroad/farm use the IDI is better I think
for everything else the 7.3 powerstroke.
I've seen a 2000 powerstroke over 800,000km on it torn down and show almost no wear at all.
I don't think I have erver seen an idi turbo over 400,000 without being rebuilt.
if its a powerstroke CHANGE YOUR OIL , they won't put up with dirty oil for long!
cheers James
[SIGPIC]
projects: all on hold for now
68Mercury250Ranger is offline
post #6 of 8 (permalink) Old 10-08-2012, 12:30 AM Thread Starter
thanks but i have 7.3 Di turbo ,air is where you say it is ,nowis it powerstroke if it does not say conflicting confusion still learning. diesel too...and e40d trans
mregan is offline
post #7 of 8 (permalink) Old 10-08-2012, 02:47 AM
where did you get the "Di" from?
idi stands for indirect injection. old 7.3/6.9
powerstrokes are direct injection but I've never seen them identified as "Di" , if you post a pic of your engine bay it is pretty easy to spot the difference.
If you can't I can take a pic of each Monday, have both at the farm and will stick them up here for you.
how many km on your new truck, there is thread for that too
[SIGPIC]
post #8 of 8 (permalink) Old 11-23-2012, 08:36 PM Thread Starter
so in learning,my carguru buddy says yes a direct injection 7.3,375 th clicks today all test say its in great shape really guit no smoking, but have noticed a constant small vibration ,at idle.hoping it was alternator bearing,but new alt and still there,only thing i have done is change trans oil and put in Rotella in engine,different then previous owner maybe it doesnt like it he used castrol,or is this normal vibration for a diesel for instance i put my hand on air filter box and feel it ...
mregan is offline
NEED HELP: Dealer oil change negligence killed my Powerstroke racer-x Diesel Trucks 6 09-25-2010 08:48 PM
