6.0L High Pressure Oil Problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 07-31-2012, 06:27 PM Thread Starter
Here's the scoop. Had the truck out yesterday. (2004 F550 6.0L 6spd 4x4) I shut the damn thing off to go shut down some stuff I was doing and it won't start back up 10 minutes later. After 2 hours, it starts and runs like it's usual self (whole other story). Apparently, the oil gets too thin at operating temp and blows by the seals in the high pressure oil system for the injectors. Got it to the mechanics, and for once, it actually acted up in front of him. So the problem can be duplicated. Anyone else ever had or heard of this being a problem? It acts up after every oil change, too.
post #2 of 2 (permalink) Old 08-01-2012, 12:01 AM
Did a full head gasket job on my 6.0 (2005 tho) and also had to repair hpop system as the STC fitting blew. I counted no less than 13 o-rings on the high pressure side. There are upgrade parts from dealer like stand pipes and dummy plugs that you will need...also I'd replace oil cooler and upgraded screen that feeds the hpop.
Exhaust Back Pressure Haley-Special F-150 1997 to 2003 /04 Heritage Forum 0 07-15-2011 08:20 AM
NEED HELP: oil pressure 89f150 F-150 Pre-1997 Forum 2 05-14-2010 02:51 PM
Tire Pressure - BFG A/T T/As Blue Oval Wheels and Tires 6 11-22-2009 01:45 PM
99 Ranger - Cold Start, Low Oil Pressure 00PowderSpecial Ranger Forum 5 12-19-2008 12:10 PM
Changed oil pressure sending unit today Larry227 F-150 1997 to 2003 /04 Heritage Forum 1 09-14-2008 05:10 AM
