6.4ltr blowing white smoke - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 05-27-2014, 02:01 PM Thread Starter
We bought a 2008 f-450 to pull our 5th wheel with and it tows just fine. It has been a money pit for the year and a half we've had it. Now all of a sudden it is blowing white clouds out the tail pipe, no loss of power and it runs fine. When I either give it fuel or let off it puffs out white smoke. It seems to be water vapour. A friend suggested it might be a head gasket? Is this a big job involving serious money? The dealer just had the cab off for other engine problems ( something to do with a cracked water pump housing or like that). The truck is stuck at the airport and is about 100 or so kms from home. Would it destroy the motor to limp it back home to the dealer? PS: there doesn't seem to be any oil contamination in the engine. The truck has 160,000 kms on it. Thanks
bacardiron is offline
post #2 of 7 (permalink) Old 05-27-2014, 11:58 PM
HD Chrome's Avatar
White smoke occurs when raw diesel comes through the exhaust completely intact and unburned. Some causes of this include
Faulty or damaged injectors
Incorrect injection timing (could be a worn timing gear or damaged crankshaft keyway).
Low cylinder compression (eg caused by leaking or broken valves, piston ring sticking, cylinder and/or ring wear, or cylinder glaze)
When white smoke occurs at cold start, and then disappears as the engine warms up, the most common causes are fouling deposits around piston rings and/or cylinder glazing. Use of our Flushing Oil Concentrate and FTC Decarbonizer address these respective problems.
Water entering combustion spaces will also create white smoke. Faulty head gaskets and cracked cylinder heads or blocks are a common cause of water entry, and are often to blame. Unfortunately, expensive mechanical repair is the only proper solution here.
HD Chrome is offline
post #3 of 7 (permalink) Old 05-28-2014, 12:35 AM Thread Starter
6.4 LTR blowing white smoke
post #4 of 7 (permalink) Old 05-28-2014, 12:59 AM
Check the other thread you posted this on
post #5 of 7 (permalink) Old 05-28-2014, 03:09 AM
I like Fords Too's Avatar
it MIGHT just be condensation in the muffler
though smoke when letting off the throttle might mean worse than that
my 5.4 used to leave long white trails behind it before I took the oil drum muffler off and swaped it for something else
when I pulled that muffler off it drained a huge puddle of water out of it
if you have had a major change in weather as the problem started this might hopefully be it
there should be a small drain hole in the muffler - might be worth the effort to try seeing if it's blocked by giveing it a bit of a reaming with something you can poke in the hole
maaybe you'll get lucky
I like Fords Too is offline
post #6 of 7 (permalink) Old 05-28-2014, 06:33 AM
The more identical threads you post, the more likely you are to get a response.
post #7 of 7 (permalink) Old 05-28-2014, 06:52 AM
lol
he musta double taped the button button
NEED HELP: Fan blowing cold air? DavidY Ranger Forum 7 06-13-2012 08:32 AM
No heat blowing from the top of the dash kwy1972 F-150 2004 to 2008 Forum 0 10-10-2011 12:14 PM
NEED HELP: heater blowing cold air westcoastranger Interior 18 11-28-2010 11:01 PM
Cloud of white smoke Ford00XLT F-150 1997 to 2003 /04 Heritage Forum 7 07-09-2010 01:28 AM
HOW-TO: smoke tailights sullivan Lighting 11 10-01-2008 01:31 PM
