6.0 headstuds - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 08-27-2008, 10:20 PM Thread Starter
6.0 headstuds
How many of you 6.0 owners out there have had the ARP headstuds done? Was under warranty or not? and if not what did it cost you?
conger is offline
post #2 of 10 (permalink) Old 08-28-2008, 11:05 PM
BMac's Avatar
I have heard of some dealers putting them in for you if you've blown your hg, but if they won't you can easily put them in yourself. As for cost I have no idea what they would charge you to install...doubt it would be cheap though
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 10 (permalink) Old 11-01-2008, 11:33 AM
Mechanic
drford's Avatar
when i worked at the dealership we did install but at the cost to the customer i now own my own perfomance shop in northern alberta and i do 3-4 sets of studs and gaskets a month
Drag racing is like sex it is more fun to do than to watch
drford is offline
post #4 of 10 (permalink) Old 11-01-2008, 04:55 PM
Is it alot of work?
www.misenermotorsports.com
Dealer for SCT, UPR, TFS, Rough Country, Rev X ETC
Mise is offline
post #5 of 10 (permalink) Old 01-31-2009, 09:46 PM
Mechanic
drford's Avatar
YUP I IS KINDA A PITA TO DO BUT ITS GOTTA B DONE
drford is offline
post #6 of 10 (permalink) Old 02-26-2009, 08:15 PM
I read on another board where a guy was claiming that Ford denied his headgasket claim when they found studs (Not original equipment, technically they can). It's a crock of .... that the studs caused the problem, but just be aware.
post #7 of 10 (permalink) Old 02-27-2009, 02:52 PM
there is usually a reason they want to install studs(perf mods,heavy loads)cause the average joe who uses his sikltr for commuting probably won't need them!(the studs have more clamping force to hold in the extra cyl press)
post #8 of 10 (permalink) Old 03-05-2009, 12:38 PM
fullyford's Avatar
the 6.0 head studs are not strong enough from the factory, plus they could have put a couple more in there, once you start adding power these motor it puts alot of stress on the already weak stubs and possibly breaking them or losing the head gasket seal. either way the arp studs are a must if you are adding power to the 6.0
http://www.f150online.com/forums/members/dirtyd88-albums-signatures-picture7437-fullyford-sig1.jpg
fullyford is offline
post #9 of 10 (permalink) Old 03-05-2009, 12:52 PM
BMac's Avatar
They come with head bolts from the factory, not studs
BMac is offline
post #10 of 10 (permalink) Old 06-02-2009, 11:33 PM
HTRDDSL's Avatar
I just got a quote from a Ford Tech who does it on the side. He charges $2800 to do the studs on my 03 Excursion. I decided to wait. I'm not having any problems but thought I would get it done anyway but not at that price.
HTRDDSL is offline
