6Litre problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 02-16-2009, 05:41 PM Thread Starter
6Litre problems
Ok so i have an 2005 f350 king ranch and the other day i noticed it started chugging a bit when you step on the throttle. Then all of a sudden it was fine. The next day it didnt want to start so i finally got it started And started driving to the shop the truck would not go over 60 kms. So when i got there i let run for awhile thoughtthat maybe i had water in the fuel it only had less then 1/4 tank. I then went to get fuel it drove alittle better. I filled it up with fuel and it was fine. So i put some fuel conditioner in it and carried on.I later left the shop and it was kind of acting up. Now its acting up more and i find the more you let it idle and warm up the better it gets but its not even close to perfect! So i scanned the computer for codes today(the engine has not yet come on) And the thing is full of codes. Every injector has a code and the injector control module aswell! Has anyone ever come across this? The truck has 122,000kms on it.
www.misenermotorsports.com
Dealer for SCT, UPR, TFS, Rough Country, Rev X ETC
Mise is offline
post #2 of 8 (permalink) Old 02-16-2009, 07:54 PM
Stainless's Avatar
I hope you still have powertrain warrenty left, I got sick of mine and sold it, it started doing the same thing, brought it in several times and they could not duplicate the concern, however if you have codes that might be a start.
Stainless is offline
post #3 of 8 (permalink) Old 02-16-2009, 11:05 PM Thread Starter
Yes i have powertrain warrenty left i just hope this is covered!
Mise is offline
post #4 of 8 (permalink) Old 02-17-2009, 08:00 AM
i didnt do it
post #5 of 8 (permalink) Old 02-17-2009, 02:55 PM
sounds like you have ficm problems(injector control module)if you have warranty take it in.
post #6 of 8 (permalink) Old 02-17-2009, 06:47 PM Thread Starter
I took it in this morning thats what it appears to need and that was one of the codes i found aswell!
Mise is offline
post #7 of 8 (permalink) Old 10-09-2009, 07:05 PM
Mechanic
roush17's Avatar
Just had my 6.0 litre in for the exact issue. FICM needed new flash update. She now runs like a champ
2006 F-350 6.0 litre
FX4 Lariat
SCT X3, Bullydog Outlook Monitor, AFE 4" Turboback
Magnaflow , DC FC II 35's, Zoodad, Pro Comp 2.5" Level, EGR Delete, AMSOIL BY-Pass
roush17 is offline
post #8 of 8 (permalink) Old 10-11-2009, 02:52 PM
zip
zip's Avatar
My 03 acted similar. I replaced the icp sensor and the injectors. I had 3 or 4 bad injectors.
Chris
75 F150, 79 Bronco
zip is offline
HID problems BMac Lighting 7 08-18-2008 10:40 PM
problems tear u a new 1 FordTough.ca Site Help? 6 11-03-2007 02:18 AM
