7.3L programmer stacking - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 05-13-2009, 06:22 PM Thread Starter
I currently have a predator programmer installed in my 7.3L and recently bought an Edge Juice with Attitude monitor for its shift on the fly ability. Neither Edge nor Predator with confirm if it is okay to stack the two together, they both try to sell me thier programmer to stack.
Question: Has anyone stacked a predator with and edge before and were there problems?
7.3stroke is offline
post #2 of 9 (permalink) Old 05-14-2009, 01:50 AM
BMac's Avatar
do not stack on a 7.3, ever...nothing good will come of it. Use one or the other
1977 Ford Early Bronco
2009 Victory Jackpot
BMac is offline
post #3 of 9 (permalink) Old 05-14-2009, 09:41 AM Thread Starter
I will probably go with the edge juice with attitude then. As I understand it, the edge does on adjust transmission shift pressure. What should I do about this if I am mainly using this truck for pulling? Any thoughts?
post #4 of 9 (permalink) Old 05-14-2009, 05:54 PM
BMac's Avatar
if you are towing make sure you monitor your trans and pyro temps so they don't get out of wack, usually a good idea to leave it on a mild tune if you plan on towing
BMac is offline
post #5 of 9 (permalink) Old 05-15-2009, 02:56 PM Thread Starter
What is the weak point in the 7.3L when you turn up the hp, is it head studs? Does stacking add too much hp or is it a timing issue as Edge has implied that the timing may be too advanced? Thoughts....
post #6 of 9 (permalink) Old 05-17-2009, 01:25 PM
dusted4eva's Avatar
I would sell off the programers and get a TW custom tuned chip for the 7.3 then there is no need for stacking anything.l
Stock 2009 F-350 Lariat 4x4 Off Road 6.8 V10
dusted4eva is offline
post #7 of 9 (permalink) Old 05-18-2009, 06:28 PM
BMac's Avatar
weak point is rods....pmr's are only good for around 400 hp or so and then its a gamble
BMac is offline
post #8 of 9 (permalink) Old 05-18-2009, 08:05 PM
I know two guys who stacked an Edge and Superchip and an Edge and Predator on there 6.6 Duramax's (not Ford's I know but still). But anyways, Stacking = bad news. The trucks had ridiculous power, like stupid power, but stuff started going wrong like blown up tranny's from too much power and sensors going haywire along with toasted injectors from serious overfueling.
post #9 of 9 (permalink) Old 07-29-2010, 01:07 AM
i have an edge evolution with a banks 6 gun stack on my 7.3. I think the key is to be reasonable with it. Not driving to the grocery store with both programmers tapped. Guages for monitoring pyros and trans temp are a MUST MUST MUST!!
cobraclone is offline
programmer? burtoj2 Diesel Trucks 45 09-04-2012 01:28 AM
Edge Programmer? Arn Programmers and Tunes 20 08-22-2009 05:34 PM
Winter Programmer johnnyo888 Programmers and Tunes 5 03-11-2009 07:06 AM
gryphon programmer simonw Sticky Tech/How to Section 2 11-26-2008 09:39 PM
Programmer error Ranger GT Programmers and Tunes 0 11-03-2008 09:40 PM
