Oil leak from dipstick. - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 08-27-2009, 10:40 PM Thread Starter
Black Ice's Avatar
Send a message via MSN to Black Ice
My 2000 f550 has a 7.3 power stroke.It developed a leak where the dipstick goes into the pan.It has a nut and a o-ring on the inside and a nut on the outside.Most dumnassed thing ive seen.The stupid thing is the o-ring is worth 5 bucks,but you have to drop the pan to change it which you cant do without lifting the engine that i can see.I phoned ford up in whitehorse and the guy said that there have been a rash of these things leaking. Anyone else have this problem?
Black Ice is offline
post #2 of 5 (permalink) Old 09-09-2009, 11:51 PM
It can be done with out removing the engine. http://www.powerstrokehelp.com/7.3liter/leaks/1of2.asp
2001 7.3 SuperDuty Lariat
AFE Stage II Cold Air Intake
PHP Tunes , Autometer Gauges
Zoodad Mod, NC Hornet's CCV Mod
4"SS MBRP Exhaust
ITP Overboost Annihilator
Roada Deco Positive Air Shutoff
NADP Heavy Hauler Transmission
6 liter Trans Cooler
BD Power Auxiliary Trans Filter Kit
Diesel Site Coolant Filtration System
PSD911 is offline
post #3 of 5 (permalink) Old 09-15-2009, 10:45 AM Thread Starter
Black Ice's Avatar
Thanks for the info.Its a pain no matter which way you go.
post #4 of 5 (permalink) Old 09-17-2009, 12:05 AM
Very true. One of those engineering flaws that come around once in a while to bite you in the behind.
4"SS MBRP Exhaust
PSD911 is offline
post #5 of 5 (permalink) Old 03-18-2010, 08:46 AM
Crazy_Canuck's Avatar
just did mine. make sure you disconnect both batteries, remove 3 bolts on starter and let it hang, remove one nut from dipstick to valvecover stud, at this point you MUST make sure you have a good grip on the piece that goes into the pan. Then remove the dipstick tube ( this is sometimes tough because there is an o-ring holding the tube inside the fitting), then install needle nose vise-grips into the spot the tube came out of, THEN remove the large nut and discard it and the o-ring inside the pan, wipe everything off as much as possible, install new o-ring (without getting it wet with oil or it will swell up and make installation a biatch), pull fitting up to inside face of pan and install new nut. snug this nut up (just because you can put a large wrench on it does not mean you also have to tighten untill you rip all the threads off the nut), remove the needle nose vise-grips and when putting the dipstick tube back in you need to be carefull the o-ring doen't get pinched, put the nut on the tube at the valvecover, install starter, and connect batteries. time to do all this about 2 hours.
NOTE: after removing the starter i washed down the side of the motor around the fitting with some varsol and a toothbrush and wiped with a rag. and i bought new needle nose vise-grips for the holding of the fitting. ( new pliers 10.00= no lost fitting, lost fitting you have three choices.
1 remove the oil pan (this requires removal of the engine)
2 cut hole in side of oil pan and then reweld after finding fitting
3 find someone with an optical borescope camera to look inside and then with a mechanical snake try to recover your fitting)
was easy to do just be clean and take your time. worked great.
2011 F350 Dually PSD CC Lariat ultimate still stock
y2k x cab 4x4, with a few extras. broke Feb 2011 collision
Crazy_Canuck is offline
Oil Leak on 91 f150 Waborita92 F-150 Pre-1997 Forum 12 05-18-2009 02:36 PM
Water Leak!! Cooker Ranger Forum 10 11-24-2008 03:02 AM
Water Leak bat052 F-150 2004 to 2008 Forum 2 11-26-2007 07:35 PM
