6.0 L Boost Gauge - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 02-27-2010, 02:32 PM Thread Starter
6.0 L Boost Gauge
So I'm looking to install a boost gauge on my 6.0L where is the best place to connect the line? I bought all of the fittings to tap and thread the aluminum elbow that is bolted to the intake. I wanted to ask before I drill the whole.
Nic
Mercuryv8 is offline
post #2 of 11 (permalink) Old 02-27-2010, 02:47 PM
zip
zip's Avatar
Here is a pic from Diesel Manor instructions.
http://www.dieselmanor.com/diy/PSD3-gauge/image22-a.htm
Chris
75 F150, 79 Bronco
zip is offline
post #3 of 11 (permalink) Old 02-27-2010, 06:55 PM Thread Starter
That looks exactly like where I was planning on putting it. They refer to a T installation. I can't find any manafold lines?
Nic
post #4 of 11 (permalink) Old 02-27-2010, 09:08 PM
T-installation is the alternative method. You are far better to tap the elbow and install there. I have installed mine there on my 07 & my past 04 with no issues. Remove the elbow before you tap it and then you will leave the metal chips on the bench.
post #5 of 11 (permalink) Old 02-27-2010, 10:31 PM
wondering why your adding the boost gauge ? out of all the gauges that are there the boost is the most accurate (next to the speedo/rpm)
said that even though aftermarket do look better
post #6 of 11 (permalink) Old 02-28-2010, 07:14 AM
zip
zip's Avatar
Nic
I just used the one line for mine.
It's an 03/7.3 I believe. No boost gauge on dash, at least I don't think so. My 03/6.0 has no stock boost gauge.
Chris
75 F150, 79 Bronco
zip is offline
post #7 of 11 (permalink) Old 02-28-2010, 07:28 AM
I think zip is right, Mercuryv8's profile says '03.
I installed in mine just because I had it left over from my '04 which I had from my '03 7.3L in a trio of EGT/boost/trans temp.
Mercuryv8, if you can go into User CP a the top beside "Forums Home", and add your truck specs in the signature box, it will show up at the bottom of your posts. That will help anyone replying to your questions/ comments.
post #8 of 11 (permalink) Old 02-28-2010, 08:44 AM
yeah whoops.... my bad ive got an 07 just figured they all had the boost gauge lol after all its an important part lol
post #9 of 11 (permalink) Old 02-28-2010, 10:37 AM Thread Starter
Yeah, 03 no boost gauge.
I'm really excited about the gauge because my turbo is on its way out and I want some baseline boost pressures to compare the rebuilt turbo too.
2003 F350 SD 6.0L Auto 4X4. Bare bones work truck but I love her anyway.
post #10 of 11 (permalink) Old 02-28-2010, 09:47 PM
You should be seeing upper 20's stock.
Eco Boost 3.5 V6 - Worth the wait? ndpeterso F-150 2009 to 2014 Forum 14 11-19-2009 11:37 PM
Alt Gauge Jumps! etniesbmx1 F-150 Pre-1997 Forum 9 11-04-2009 07:30 AM
GAS GAUGE enjoy425 F-150 1997 to 2003 /04 Heritage Forum 2 04-12-2009 12:37 PM
Aeroforce Scan Gauge Chuck P Audio and Electronics 12 10-23-2008 08:16 PM
White Gauge Overlay Chienlaid Ranger Forum 5 03-04-2008 09:49 PM
