Rear end - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 04-22-2011, 05:39 PM Thread Starter
Rear end
Right now ive got an open diff looking to have installed a limited slip or posi unit has anyone done one on an 07 F350 ? trucks 4x4 so cant change gearing without changing the front aswell (not spending that much moula right now lol)
who would you recomend ? (product wise)
I hate an open diff PITA.
post #2 of 5 (permalink) Old 04-23-2011, 12:20 AM
eaton true track!!
post #3 of 5 (permalink) Old 04-23-2011, 10:47 AM
I have a guy here in Peterborough that does my rear gear work. There is definately a talent to getting them set up properly. Polito Ford in Lindsay did my 2003 twice under warranty and still couldn't get it right. So a nice white lab coat with a Blue Oval on it is no guarantee.
BTW, I dont know what you were referring to about re-gearing (going up or down in ratio) but I have a brand nnew set of 3.73 Crown & Pinion gears from Ford for the front which I ended up not needing available for sale cheap if that helps.
post #4 of 5 (permalink) Old 04-23-2011, 03:44 PM Thread Starter
I want to go bigger tires but not big enough to need to re-gear and the expense of doing the front is huge compared to the rear alot more labour intensive, plus its a daily driver.
mainly its to help with traction on a wet road taking off from a stop sign i get onewheel peel and in the winter its worse lots of torque no traction.
thanks for the offer on the gears thats whats in it now so no point in switching them out lol
true trac eh... will look into them
post #5 of 5 (permalink) Old 04-24-2011, 09:19 AM
Gotcha. I had a posi unit for the rear but it magically ended up in my buddys '03. I'm not sure how it happened...
Rear end 99fx4 F-150 1997 to 2003 /04 Heritage Forum 3 11-18-2009 01:23 AM
Rear end cover? joetalon F-150 1997 to 2003 /04 Heritage Forum 4 08-21-2009 11:24 PM
Rear end fluid ?? joetalon F-150 1997 to 2003 /04 Heritage Forum 4 08-20-2009 06:48 PM
Rear end tag swackly F-150 2004 to 2008 Forum 3 01-06-2009 07:59 AM
Rear end problem alpine F-150 2004 to 2008 Forum 13 04-29-2008 10:50 PM
