A little sarcasm... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 06-16-2012, 10:06 PM Thread Starter
A little sarcasm...
Are Ford's foot/pounds different from everyone else's??? My engine can't produc e 470 ft/lbs without help. The zf s5-47 is supposed to handle 470 but the output shaft says nay, nay!! NP 205 transfer case is in great shape but the splines on the zf are almost stripped. Alignment was good and case bolts were tight. I'll try to get a pic of it here tomorrow.
