Transmission Leak ... - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 15 (permalink) Old 04-05-2014, 09:10 AM Thread Starter
TRUKNUT's Avatar
Post Transmission Leak ...
I did an oil change on my 09 last week to get it ready to come out of storage and I found a puddle of trans fluid under it . I can see it leaked from the rear of the pan . I don't remember seeing that when I parked it ... Anyway I need to get it fixed . What do you guys think ... Dealer repair or transmission shop ? The truck is out in Belleville and I'll have to find a shop out there to service it .
TRUKNUT is offline
post #2 of 15 (permalink) Old 04-05-2014, 11:05 AM
Yah, that's a pretty subjective call only you can make Larry.
For what it's worth, I don't have a whole lot of confidence in the chain specialty shops, whether its transmissions or exhaust or whatever.
But, I'm biased toward the dealership I go to, just because I've been getting all my vehicles serviced there for the last 10 years or so.
I've got a pretty good working relationship with them, and never had any issues with the work that was done, so I'd be inclined to stick with what I know.
I can see the advantages of going to the chain specialty store, all they do is transmissions, but for a simple fluid and gasket, I'd still go dealer.
post #3 of 15 (permalink) Old 04-05-2014, 11:55 AM Thread Starter
TRUKNUT's Avatar
I was thinking the same thing . I'm hoping to get some feed back on one of the dealer ships in the Kingston / Belleville area .
TRUKNUT is offline
post #4 of 15 (permalink) Old 04-05-2014, 02:18 PM
Atra.com
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #5 of 15 (permalink) Old 04-05-2014, 03:51 PM
Self service!
post #6 of 15 (permalink) Old 04-05-2014, 04:06 PM Thread Starter
TRUKNUT's Avatar
Post
Originally Posted by Destructicon View Post
Self service!
I'm not sure what the problem is here … If the leak was there when I parked the truck in Oct or If something happen over the winter to cause the leak .
So I'm going to hazzard a quess and say that a replacement transmission is not cheap so better to aire on the side of caution and have someone who knows what to look for service it . So self service is not an option in my mind …
TRUKNUT is offline
post #7 of 15 (permalink) Old 04-06-2014, 06:29 AM
Tighten the pan bolts and top it up. Or if your feeling adventurous, R/R the pan gasket and filter and put some fresh fluid in. Your transmission will love you for it.
post #8 of 15 (permalink) Old 04-06-2014, 10:25 AM
TRNRBILT's Avatar
If I remember correctly with my 2009 you can't top it up. It's a dealer only trans service on these ones.
TRNRBILT is offline
post #9 of 15 (permalink) Old 04-06-2014, 07:41 PM Thread Starter
TRUKNUT's Avatar
Post
I did a little research over the weekend and your are correct … This ones going to the dealer for service next week .
Thanks to all for your input .
TRUKNUT is offline
post #10 of 15 (permalink) Old 04-07-2014, 10:49 AM
Canadian Bacon's Avatar
Is it a 6R80? There is a connector to the valve body that the oring goes and have to replace the whole connector 6L2Z-7G276-AA, as well as just the pan gasket itself BL3Z-7A191-C, both very common. Just like the Power Steering Pressure Line.
Emily - 2010 Ford F-150 FX4
Amsoil Independent Dealer
Amsoil Home Page
Canadian Bacon is offline
NEED HELP: Exhaust Leak-i think? blaster23 F-150 2004 to 2008 Forum 18 06-19-2011 12:38 PM
Propane Leak? Knightruler Gas Engines 0 08-21-2010 11:08 AM
WATER LEAK Blaizz F-150 1997 to 2003 /04 Heritage Forum 1 03-16-2010 12:45 AM
Exhaust leak Fordwheeler F-150 1997 to 2003 /04 Heritage Forum 21 08-13-2009 06:45 PM
Water Leak!! Cooker Ranger Forum 10 11-24-2008 03:02 AM
