Took a while - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 11-27-2014, 02:44 AM Thread Starter
zip
zip's Avatar
Took a while
So I had the issue of no 4wd. I checked plugs, hubs, shafts, switches and whatever I could think of.
I could see the front driveshaft turning with the truck in gear and rear tires turning. Hubs locked couldn't turn axles. All seemed normal but still no 4wd/
In a brainstorm moment I decided to put the stock hubs on to see if that made any difference. Low and behold it did. While taking the drivers hub off something didn't look the same as the other. It seems that there were a couple pieces left behind.
Chris
75 F150, 79 Bronco
zip is offline
post #2 of 3 (permalink) Old 11-27-2014, 10:29 AM
So what caused the snap ring to pop out? Not fully locked at one time?
post #3 of 3 (permalink) Old 11-27-2014, 11:52 AM Thread Starter
zip
zip's Avatar
I couldn't tell ya. Maybe not installed correctly. I did have that whole side apart last year. Something may have happened then.
Chris
75 F150, 79 Bronco
zip is offline
