no reverse - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 01-27-2015, 07:23 PM Thread Starter
no reverse
Hi I'm new to the site and I'm having problems with my 1983 diesel ford ranger (150k) with the reverse. I was driving it around earlier today and when I put it in reverse it worked fine the when I parked it I tries to backup and nothing happened I took my foot off the clutch and it seemed to be in neutral like nothing happened to I was wondering if anybody had any insight on it thanks a lot
diesel_ian is offline
post #2 of 6 (permalink) Old 01-27-2015, 08:03 PM
TRNRBILT's Avatar
Do you have any forward gears? Specifically 2nd? It and reverse are usually the same gear if I remember correctly.
TRNRBILT is offline
post #3 of 6 (permalink) Old 01-27-2015, 08:37 PM Thread Starter
Yes sorry I have all other gears (4)
post #4 of 6 (permalink) Old 01-27-2015, 08:39 PM Thread Starter
And i can still put it in to the reverse gear but nothing happens
post #5 of 6 (permalink) Old 01-27-2015, 09:58 PM
Check that the drive shaft is turning or not in reverse. If it is, then check the rear axle.
post #6 of 6 (permalink) Old 01-28-2015, 12:30 AM Thread Starter
Ok thanks I'll try that
terrible reverse lights Bandit993 F-150 2009 to 2014 Forum 90 01-03-2013 11:42 PM
Reverse Light Solutions? RedThunder Exterior 10 01-25-2012 12:04 PM
2010 reverse systems aspinape F-150 2009 to 2014 Forum 1 09-14-2009 01:36 AM
Reverse Sensor going off for nothing RJohn357 F-150 2004 to 2008 Forum 10 01-27-2009 09:31 PM
08 Reverse Camera? 04STXHERITAGE F-150 2004 to 2008 Forum 15 12-22-2008 07:49 PM
