Axle Seal - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 03-26-2008, 01:32 PM Thread Starter
Axle Seal
Hey. I just noticed that the inside of my passenger rear rim is wet, and upon further inspection it looks like the axle seal is leaking. Im looking at changing it myself as I am going to be installing a brake kit as well and half the parts will already be off. The only question i have about the job is how to pull the axle out. I havent really gotten inside one of these rear diffs before so im just curious how hard it is to take the retaining clip out so you can pull the axle out. I went by ford but it doesnt really show hows its held in there, just that there is a clip in the diff. Anyone that can give me some info on how hard it is?
Roadwarrior is offline
post #2 of 9 (permalink) Old 03-27-2008, 12:43 AM
Do you have a Hayne's or a Chilton's manual. I can check mine but not sure what year your truck is.
post #3 of 9 (permalink) Old 03-27-2008, 10:32 AM Thread Starter
Its an 04 with the 9.75" diff. Ive talked to a few people and it should be pretty easy. Pull all the hardware off, pull the diff cover, push in the axle to expose the c-clip, remove it and pull the axle.
post #4 of 9 (permalink) Old 03-27-2008, 12:03 PM
Ok then my manual will not help then. If it did I was going to scan the pages and post em.
Good luck with the fix. Getting mine rebuilt this Aug.
post #5 of 9 (permalink) Old 03-29-2008, 07:20 PM Thread Starter
Well got it all done. Was actually pretty simple to do, took about an hour or 2 and most of it went really smooth.
post #6 of 9 (permalink) Old 03-29-2008, 09:06 PM
1white08fx2's Avatar
Was going to say this is the way,and is very simple to do.
But you got it all done,and glad it all worked out for you! :icon_wink:
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #7 of 9 (permalink) Old 03-30-2008, 01:16 PM Thread Starter
Ya the most difficult parts were just finding the right size socket to take the pin out of the diff, and getting the rotor off of the axle. But after a bunch of brake clean and some scraping and everything its all clean and good to go again.
Next weekend, all new rotors and pads.
post #8 of 9 (permalink) Old 04-10-2008, 09:40 PM
any special tools to change it? how hard is it to pull the seal out? or put back in? i noticed mine leaking today, wet rim,, i thought it might have been the caliper,, so i got a new one,, and apparently its not the caliper,, its the seal,, i might tackle this one tomorrow,,
04fx4 is offline
post #9 of 9 (permalink) Old 04-10-2008, 11:09 PM Thread Starter
To take out the old seal we just kept tapping it with a screwdriver and hammer till it was kinda bent out of shape and came out really easy. If you had a seal driver it would probably make it easier to put in, but all we did was take a hammer and a 6" piece of flat iron and slowly tapped it and moved the iron around till it was seated all the way.
R.I.P. - 2004 F150 FX4
97 Ranger rear axle seal replace Jim West Driveline and Transmission 1 11-09-2008 03:20 PM
Possible Bent Axle? RangerBoy Ranger Forum 10 10-01-2008 07:47 PM
04 up f150 axle upgrade 1234 Wheels and Tires 28 02-13-2008 11:38 PM
AXLE CODE DECODER fordtough.ca Sticky Tech/How to Section 0 11-15-2007 06:38 PM
Tailgate Seal? MaxPower Exterior 6 02-28-2007 03:55 PM
