Tranny Temp sensor - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 08-13-2008, 12:31 AM Thread Starter
Tranny Temp sensor
Well as i mentioned in one of my other posts, i was looking at putting a transmission temp guage in my truck. So ive gotten most of the stuff figured out, but today my brother said someone at work mentioned there being a plug that i can put the sensor in without having to drill my pan. Just pull out a plug and screw the sensor in its place. Does anyone know where this plug is? If anyone can snap a pic that would be amazing, i just dont wanna pull out the wrong plug. Any help will be great.
R.I.P. - 2004 F150 FX4
Roadwarrior is offline
post #2 of 11 (permalink) Old 08-13-2008, 12:44 AM
the only plug on the pan i can think of is the drain plug. if your truck even has one of those. not sure if my 05 has one either. i hope he's not talking about this plug. The wires would be in harm's way hanging down there.
post #3 of 11 (permalink) Old 08-13-2008, 12:49 AM
See if you can find an EDGE programmer on e-bay
It will give you 4 gauges of your choice in one, utilizing engines PCM
post #4 of 11 (permalink) Old 08-13-2008, 01:37 PM Thread Starter
Dont want to get an edge, i have a custom guage pod that im making for my dash that is mostly finished. The spot that the person had mentioned was a spot on the case of the transmission, not in the pan, cause ya mine doesnt have a drain plug. Although if i did end up having to tap my pan for the sensor i was going to install a drain plug as well.
post #5 of 11 (permalink) Old 08-13-2008, 02:44 PM
That explains
if you thinking of taping it in
Than I would go for deeper pan and do all the work before you install it
Can't wait to see the pod design
post #6 of 11 (permalink) Old 08-13-2008, 08:32 PM Thread Starter
Hopefully it should be done in a day or 2. The pod is turning out pretty decent. I still dont understand why autometer doesnt make one for that spot on the truck, seems like kind of a no brainer location.
post #7 of 11 (permalink) Old 08-13-2008, 10:24 PM
I have a E4OD tranny and put mine in the test port of the tranny
post #8 of 11 (permalink) Old 08-14-2008, 11:31 AM Thread Starter
Ya i think thats where i was told i can put it in, was just wondering where to look for it.
post #9 of 11 (permalink) Old 08-14-2008, 06:39 PM Thread Starter
Im just curious, i was under the truck looking at things, and there was a spot on the drivers side of the tranny case that had a little plug and says line on it, is there where i would put the sensor?
post #10 of 11 (permalink) Old 08-17-2008, 10:08 AM
Tranny temp gauges are very useful.....I would have suggested the scangauge II but you already have things in motion.
good luck.
primerib is offline
tranny Q. rangerT Ranger Forum 14 10-11-2008 05:38 PM
Which Tranny rebelk Driveline and Transmission 3 08-12-2008 10:12 PM
Which Tranny Roadwarrior Driveline and Transmission 5 08-10-2008 03:34 AM
camshaft sensor zarbatad Super Duty Forum 1 12-08-2007 12:35 PM
