NEED HELP: Fx-4 tranny issue? - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 11-02-2008, 09:40 AM Thread Starter
Unhappy Fx-4 tranny issue?
Truck shudders in reverse gear? This started 2 weeks ago when in reverse the truck shutters. Talked to service manager he suggested going 30 mph downshifting into 1st gear to see if the issue can be repeated it did not repeat the same shudder, the engine breaked down the truck to a stop which its suppose to do. This truck has only 4700 km on it. The other issue it had was when brand new was it kept pulling to the right, the aligement was dead on i think they switched the tires around to fix that issue any one else having or had the tranny issue? The next step is to have some gauges put on the tranny to check pressure? I am feeling sick, about this, not a good feeling in the pit of my stomach? Very disapointed in this truck too many little issues now this what is next?
villain is offline
post #2 of 7 (permalink) Old 11-02-2008, 10:25 AM
welcome to the site. can't help with the tranny other than maybe trying another dealer. are they getting any codes? we have a great tech guy on here, maybe he'll chime in soon with some help.
post #3 of 7 (permalink) Old 11-02-2008, 10:43 AM Thread Starter
No codes the engine does not rev down it stays the same througout the shudder?
villain is offline
post #4 of 7 (permalink) Old 11-03-2008, 12:13 AM
Robert:when vehicle shudders is it just in rev or moving in rev?there are a couple of tsb's pertaining to this concern,and for the pull does it have a vibration from steering wheel or body when driving also?
post #5 of 7 (permalink) Old 11-07-2008, 05:33 PM Thread Starter
Shudders only when shifted into reverse and as soon as you remove your foot from the break pedal it shudders also if you hit the accelerator pedal in reverse the shudder in much more prevalent.
villain is offline
post #6 of 7 (permalink) Old 11-07-2008, 11:22 PM
ther was a tsb for the park brakes hanging up,lift the rear wheels off ground and se if turn free by hand,than see if the park cables are hanging up,also check to see if you have a seal leak(just remove the adjuster plugs and look inside),and for the vibration/pull do you have pirelli 20" tires ijust replaced one for the same concern on my truck.
post #7 of 7 (permalink) Old 11-08-2008, 02:37 PM Thread Starter
Yes 20" on my truck I am going to check that out thanks.
villain is offline
Which Tranny Roadwarrior Driveline and Transmission 5 08-10-2008 03:34 AM
DRL issue notmuchmud Lighting 5 07-05-2008 10:44 PM
FORD re-issue recall for cruise control f150phule F-150 2004 to 2008 Forum 3 03-10-2008 11:12 PM
battery issue stevet F-150 2004 to 2008 Forum 3 12-07-2007 09:58 AM
