NEED HELP: Trans crossmember - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 11-15-2008, 09:19 AM
rickwest
Guest
Posts: n/a
Question Trans crossmember
Hello all
I am new here and looking for some advice. I recently changed the clutch in my 97 Ranger regular cab and wound up needing a new rear crossmember. The one I found at the wrecker LOOKS similar but the angles and distance between the bushings is not identical.
Is it possible that one is from an auto trans and mine is different because it is a manual trans? The guy at the wrecker says it SHOULD fit but let me tell you--it does not work.
Rick
post #2 of 3 (permalink) Old 11-15-2008, 02:34 PM
post #3 of 3 (permalink) Old 11-15-2008, 04:41 PM
are you saying the total width is different or the thickness of crossmember?
