Tranny Question PLEASE HELP - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 12-01-2008, 08:35 PM Thread Starter
Hello my grandfather has a 2000 f150 2wd 4.2l regular cab auto with overdrive. His transmission is gone and were looking for another one wanted to know what other year tans will work with a 2000 or if any of the v8 trannys will work. appreciate the help
OldSkoolKool is offline
post #2 of 7 (permalink) Old 12-01-2008, 10:15 PM
look at the doorjam sticker for the tranny code
post #3 of 7 (permalink) Old 12-02-2008, 01:14 AM
I think most 4.2s came with the 4R70W trans. I believe that the same trans is in the 4.6 and 5.4 v8s but the bolt pattern on the bell housing is not the same as the 4.2, not sure if you can use your bell housing on a trans from a v8.
post #4 of 7 (permalink) Old 12-02-2008, 02:59 PM
whats gone on the trans,the 4r70w is fairly easy and inexpensive to rebuild.
post #5 of 7 (permalink) Old 12-04-2008, 09:47 AM
Justin1635's Avatar
"Tranny question"... if it is a woman but it looks like a man..well it probably is LOL
just kidding, well... no im not, but have you checked any wrecker yards for year 2000 trucks?
"The Dark Knight"
Justin1635 is offline
post #6 of 7 (permalink) Old 12-04-2008, 09:57 PM
Yes, the 4.2L uses the same bolt pattern as the 3.8L and its variants..
A bit of an odd and maybe wrong suggestion, but if he likes 5 spd trannies then its not too terribly difficult to swap them, and probably about the same price as a rebuild. LR
post #7 of 7 (permalink) Old 12-05-2008, 08:48 PM Thread Starter
well the transmission was supposed to be rebuilt by a guy and then re installed in the truck. well he used the old bell housing seal and it ended up blowing that one. Then he put a new seal in it and worked fine for a month or so and the guy went out of businness now he has no reverse and the forward gears are slipping.
Could this be the torque converter maybe ???
Thanks sorry for the rambling on lol...
tranny Q. rangerT Ranger Forum 14 10-11-2008 05:38 PM
Which Tranny rebelk Driveline and Transmission 3 08-12-2008 10:12 PM
Which Tranny Roadwarrior Driveline and Transmission 5 08-10-2008 03:34 AM
tranny 4x4.0 Driveline and Transmission 2 03-17-2008 06:44 PM
