NEED HELP: driveline noise - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 01-22-2009, 12:45 AM Thread Starter
driveline noise
like the title says theres a constent hum then driving the explorer sort of like tire noise but its not the tires.... and when i turn right the noise stops completley from stop to say a 100 the noise increases gradualy with the speed but if i were to take an offramp at 50/60/80/100 the noise stops
wheel bearing ?
cv shaft ?
drive shaft ?
rear end ?
front end ?
transfercase ?
its getting more and more anoying
oh its a 4.6 awd explorer with 4hi and 4lo
post #2 of 4 (permalink) Old 01-22-2009, 02:59 PM
if the noise changes while shifting body wieght(turn wheel slightly back and forth while driving)is most likly a wheel bearing.
post #3 of 4 (permalink) Old 01-22-2009, 04:20 PM Thread Starter
thanks i was figuring that there bad for them i guess now to try and find out what ones bad
post #4 of 4 (permalink) Old 02-06-2009, 04:34 PM
use a set of chassis ears for diagnosing it. it's the only way to go.
ronburgundy is offline
4X4 High Noise trevor7696 Driveline and Transmission 9 12-25-2008 03:07 PM
NEED HELP: Grinding Noise Coruptyed Gas Engines 8 12-06-2008 03:49 PM
front end noise help mud flies Ranger Forum 5 08-10-2008 08:59 AM
engine noise on start up??? silverfox Gas Engines 14 09-24-2007 10:50 PM
