Clunk when I shift into 4 hi - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 7 (permalink) Old 02-02-2009, 07:13 PM Thread Starter
When I shift into 4 hi I get a clunk is it normal? I have a 2004 F150 FX4 screw.
Silver FX4 is offline
post #2 of 7 (permalink) Old 02-02-2009, 09:17 PM
tohi2care's Avatar
Yes and no. If your driving at speed and engage 4hi and hear it then yes it's a problem but if your at a stop and step on the gas a bit before the hubs fully engage then it's not a real issue just keep off the throttle a bit. Also in the cold I notice that the hubs take quite a bit longer to engage so the clunk is easier to produce. also is it more a bang then a clunk.?
tohi2care is offline
post #3 of 7 (permalink) Old 02-03-2009, 02:59 PM
does it actually go into 4x4?have seen concerns with the front wheel locks vacuum system.
post #4 of 7 (permalink) Old 02-03-2009, 10:38 PM Thread Starter
It goes into 4x4 I think it was because I was not moving.
post #5 of 7 (permalink) Old 02-26-2009, 10:36 PM
Justin1635's Avatar
make no sense, your post does...mmmmmm
"The Dark Knight"
Justin1635 is offline
post #6 of 7 (permalink) Old 02-27-2009, 05:17 AM
If there's still any torque load on your driveline (ie tranny in gear) then yes, its normal. I've never owned an auto shift 4wd setup so I've never used one, but IIRC you can still shift into 4 hi while driving or while in gear so a clunk would be considered normal (small clunk). Anything heavy and very produced could be a sign of a worn t-case of u-joints, or loose driveline components. LR
post #7 of 7 (permalink) Old 02-28-2009, 02:25 AM
Mar
Mar's Avatar
A clunk is most likely caused by a u joint. Change one, change them all at the same time.
Mar is offline
shift kit truckman79 Driveline and Transmission 6 05-17-2009 01:22 PM
shift kit? canadian.bacon Ranger Forum 4 12-09-2008 08:33 PM
