NEED HELP: transmission concern - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 02-17-2009, 10:20 PM Thread Starter
took my 08 f150 with 3500 km to dealer concerned with the transmission having a harsh 3-2 downshift when slowing down during a turn and then accelerating to create the downshift. It also feels the shifting is just not timed correctly (to early on the upshift and a delay on the downshift while driving). Took the tech for a drive and he felt the harsh shift but stated it was normal. I have owed many trucks in the past (not fords this is my first) and not one had this type of shift concerns. Is this normal for the Ford f150 with a 5.4L or was I just given the brush off. Sorry for the length of this post any comments would be great.
thanks
parkside is offline
post #2 of 3 (permalink) Old 02-18-2009, 05:08 PM
Armen's Avatar
Yup... My 06 does the same kind of thing. I bought a programmer to make the shifts a bit stiffer, but it only helps a bit.
Armen is offline
post #3 of 3 (permalink) Old 02-18-2009, 07:36 PM
does this occur at lower speeds(40-60kmh)?if so is fairly normal i've found that when driving steady 40-60kmh to select o/d off will lessen this concern(trans won't be hunting between gears)
What Transmission do you have? fordtough.ca Driveline and Transmission 34 04-04-2010 11:00 AM
transmission question Jensen F-150 Pre-1997 Forum 3 02-08-2009 05:24 PM
ford transmission spotter's guide Northern Supercrew Sticky Tech/How to Section 3 09-26-2008 02:21 AM
What Transmission Temperature......... fordtough.ca Driveline and Transmission 1 06-29-2008 12:02 AM
What Transmission? Disposable-Hero F-150 Pre-1997 Forum 5 01-23-2008 12:26 AM
