1999 F150 won't engage in 4 wheel drive - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 03-26-2009, 11:16 PM
ChrisB
Guest
Posts: n/a
When I manually put in 4x4 (stick) I can hear the solenoid click. Dash light comes on, and it seems like it shifts into 4 low, but no deal. Same in 4 high nothing.
Any ideas?
post #2 of 4 (permalink) Old 03-27-2009, 12:31 AM
09'FX4's Avatar
check the fuse first off, my 98 ranger would click and the dash light came on but a fuse was missing i replaced it and boom 4x4 engaged no problem. this was with a turn nob to engage tho not a manual stick but could still be worth a try
09' Ford Ranger Fx4 5-speed Black
09'FX4 is offline
post #3 of 4 (permalink) Old 03-27-2009, 02:16 AM
Is your ABS light on? Might have a busted hub, vacuum line. Are they manual hubs with stick??? Defiantly check fuses first for sure, would be the cheaper fix.
If you need to get new hubs watch what they order I know with my 99 has full auto 4x4 and I can get two different hubs Ford hubs over 500$ the aftermarket ones 175$ I have been running the 175$ hubs without a problem for over a year and I'm hard on my 4x4.
post #4 of 4 (permalink) Old 03-27-2009, 03:06 PM
the 97-03 f150 uses a vacc actuated shift fork for the front diff lock,probable causes of no lock is vacc lines "rotting out" behind battery box and or broken shift fork.
1999 ranger sas lonerangerxlt Ranger Forum 5 12-15-2008 05:39 AM
03 F150 XTR xtend cab-wheel bearings gman F-150 1997 to 2003 /04 Heritage Forum 5 06-29-2008 07:46 PM
Went for a drive SCREWDRIVER Photo and Video Gallery - Members Rides 7 04-14-2008 06:53 PM
