Troyer Trans Cooler - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 06-14-2009, 04:31 AM Thread Starter
Troyer Trans Cooler
Anybody install one of these?
http://www.troyerperformance.com/cgi...gno=PPI-ATCKIT
Looks pretty good. Fan cuts in at 180 F and out at 170 F.
I was in the 205 F range most of the time, with a peak of 238 F while towing my 30 ft trailer a few weeks ago. So am looking to install one of these. Same money as a Mag-Hytec pan....but it should work alot better.
06KingRanch is offline
post #2 of 5 (permalink) Old 06-14-2009, 01:23 PM
I was actually looking at the one from Troyer to replace the one I had in my truck But I went with a Derale part #13750 from summit racing http://summitracing.com/parts/DER-13750/ and a Derale 13021 Thermostatic Fan Control also from Summit racing http://summitracing.com/parts/DER-13021/ when this was wired I used a 5 pin relay and added a manual switch as well by changing to this cooler the transmissin temps dropped at least 30 degrees
I have a a deeper trasmission pan in my collection of uninstalled MOD'S I will be adding as well I went with a PML pan that I found on E bay you can see PML pans herehttp://www.partshp.com/Pans.htm
http://www.partshp.com/chart.gif
post #3 of 5 (permalink) Old 06-15-2009, 08:12 AM Thread Starter
Thanks for the info....looks like pretty much the same as the Troyer setup....but a bit cheaper. How did they ship? USPS?
post #4 of 5 (permalink) Old 06-15-2009, 10:12 AM
They ship Fed Ex or UPS I picked mine up at the Ohio store when I was there a couple years back
post #5 of 5 (permalink) Old 06-15-2009, 11:32 AM Thread Starter
cool......thanks for the info.
Scott
RELOCATED MY TRANNY COOLER.... THE H.P FREAK Ranger Forum 5 01-15-2009 12:53 AM
NEED HELP: Trans crossmember rickwest Driveline and Transmission 2 11-15-2008 04:41 PM
Troyer tunes f150phule Programmers and Tunes 7 06-12-2008 12:31 PM
troyer performance 1234 Programmers and Tunes 10 02-28-2008 04:55 PM
