3.55 gears with 33's - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 11 (permalink) Old 10-11-2009, 03:44 AM Thread Starter
bor5.4x4's Avatar
Hey I'm planning on purchasing some 33" tires for my 5.4 with 3.55's. I do tow/haul a bit but nothing crazy heavy. Does anyone think it's worth regearing for or should it be alright? Thanks.
bor5.4x4 is offline
post #2 of 11 (permalink) Old 10-11-2009, 06:27 AM
id say they would be fine its not that much larger of a tire
post #3 of 11 (permalink) Old 10-12-2009, 11:38 PM
What is tow/haul a bit? 3.55's is already terrible gears for towing. What is your stock tire size? I say it will be marginal at best, for towing or hauling anything.
post #4 of 11 (permalink) Old 10-13-2009, 10:03 PM Thread Starter
bor5.4x4's Avatar
I own a small construction business on the side and haul tools, lumber, junk, etc. I tow a cargo trailer full of tools from time to time, it's not my full tie job so I'm only doing this a bit. I might be doing it a lot more in the future though, things are getting busy and I might leave my current job. Stock tire size is 255 70 17 (31") pretty standard stock size on these trucks.
bor5.4x4 is offline
post #5 of 11 (permalink) Old 10-13-2009, 11:17 PM
for milage it should be ok,but will lack slightly in bottom end torque,also don't forget to recalibrate pcm for tire size as it will cause all kind of problems(the 93 460 i just bought was a total dog and the speedo was a way out cause someone calibrated wrong,now i can't keep tires from roasting)
post #6 of 11 (permalink) Old 10-14-2009, 07:58 PM
what truck are u putting it in .....if its a older model then if ur towing i would go to a set of 4:10s .. if its a newer model the trucks came with 33s stock or near to that size. i wouldnt bother
post #7 of 11 (permalink) Old 10-16-2009, 09:14 PM
Mechanic
i just put 33's on my truck 06 xlt with 2.5 level lift. i haul lot of tools and shit we rip out of job sites to the dump and it has no problem the ass gets a little low when its over the bed rails but its a half ton soooo.
more pics in gallary
greg86 is offline
post #8 of 11 (permalink) Old 10-17-2009, 02:53 AM
the stock tires on a 2004-2009 fx4 even the new f150 are 33s i think there 285/65/18. witch is close to a 33. 35s fit with the leveling kit.
post #9 of 11 (permalink) Old 04-04-2010, 12:45 PM
265/65/18 is a 31.5
post #10 of 11 (permalink) Old 04-04-2010, 07:48 PM
Stock tire size on an 04+ FX4 is 275/65/18 which is a 32.1" tire. I think most of the new 4x4 F150's have tires in that general size range. 33's and 3.55's will be fine I think.
Which GEARS duckdog F-150 2009 to 2014 Forum 4 11-12-2008 07:23 PM
Need Opinions on Gears Dank_44 Driveline and Transmission 7 11-06-2008 12:32 PM
