NEED HELP: 2nd gear went on vaca - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 8 (permalink) Old 11-23-2009, 12:37 AM Thread Starter
Yellow everyone... i picked up a 5.4 with trans today and its out of a 2004 super duty. its a 4R100... (guy) i got it from said trans works but, slips in to second gear. ( not a + shift) and slips wile in second. but works fine in 3rd and has firm shift into 4th, OD does work. lookin for some hints to look. borg-warner makes a HD rebuild kit for $650....... so ya im lookin at somthin on the cheep...lol
was thinkin it could be 2nd gear solenoid pack, or pressure valve or clutch,(guy ) thought it would be the band, i said it was .......lol so i got the trans for $150....woot
post #2 of 8 (permalink) Old 11-23-2009, 12:44 AM
sounds like a torn seal Philly,will probably have some clutch damage also,just take the pan off to verify,what a steal!!the core is worth more than that.
post #3 of 8 (permalink) Old 11-23-2009, 01:03 AM Thread Starter
lol i know... i got the motor with harnes, trans with converter. all for $650 the motor only had 140,000 ish on it... did compression test, to see if it was good ......YUP it was good
post #4 of 8 (permalink) Old 11-23-2009, 02:13 AM
I hate 2nd gear issues! Remember Windsor Weekend for me Phil? lol
post #5 of 8 (permalink) Old 11-24-2009, 08:37 PM Thread Starter
lol ya .. my 6 banger way still faster.....
post #6 of 8 (permalink) Old 11-25-2009, 06:29 PM
it won't be the solenoids, they almost never fail on these units. look for a hung valve in the accumulator body. when you get it together, run a pressure gauge on it to confirm proper line rise. i like to the throw the transgo tugger kit in them as well. and expect to do all the work over again shortly if you don't flush or change the cooler and the change the torque convertor.
ronburgundy is offline
post #7 of 8 (permalink) Old 11-25-2009, 06:52 PM Thread Starter
its all goin all new... i new it would be the accumulator.. thanx
post #8 of 8 (permalink) Old 12-13-2009, 01:52 PM
Originally Posted by adveddy09 View Post
No matter what broke, its time to pulling it apart. Drain your gear oil to confirm internal damage and take it to the specialist.
You did not have clutch slipping before?
Good Luck,
Artie
pretty sure he bought the setup for a donner project so he wouldnt know the trans was slipping
going to sparta october 2nd v8ranger Ontario 38 10-20-2009 06:13 PM
Toronto Bike Show - January 2nd, 2009 Swoosh66 Photo and Video Gallery - Members Rides 4 01-07-2009 01:36 PM
Yonge Steeles 2nd Annual Car Show 4X4 EH Ontario 0 07-04-2008 11:14 AM
Speedo gear help SKRWZ Wheels and Tires 0 12-10-2007 12:00 AM
