NEED HELP: clunking noise when I turn sharp - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 9 (permalink) Old 03-12-2010, 06:56 PM Thread Starter
My 2005 f250 makes clunking noise when I turn sharp but not all the time any help would be great.
xlt trucker is offline
post #2 of 9 (permalink) Old 03-12-2010, 07:37 PM
Welcome. A bit more info might be helpful like 2wd or 4wd, turning left or right or both and what speeds this happens at.
post #3 of 9 (permalink) Old 03-13-2010, 09:19 AM Thread Starter
Sorry for the missing info it is 4wd happens turning both ways and at slow speeds.
post #4 of 9 (permalink) Old 03-14-2010, 01:41 PM
offroadaction's Avatar
Check your axle u-joints and ball joints for play.
offroadaction is offline
post #5 of 9 (permalink) Old 03-14-2010, 03:28 PM
Finally, I found this thread again. Good start, follow this up with tie-rods and other steering linkage parts, stabilizer, radius arm, and pivot point bushings. Same with shock absorbers and springs and their related fasteners. Does it seem the same in 2wd as 4wd? I'm not as familiar with 2005 trucks as others would be, not even sure if they still use the twin I-beam type design, but the premise is sound. Wherever you have a rubber bushing, it will ultimately wear out.
post #6 of 9 (permalink) Old 03-14-2010, 04:18 PM
sounds like a u joint ....
post #7 of 9 (permalink) Old 03-15-2010, 07:23 AM Thread Starter
Thanks for your help I will check it out.
post #8 of 9 (permalink) Old 03-15-2010, 03:10 PM
smokum's Avatar
I had what sounds like the same issue and chased it for weeks thinking it was something obvious.
Turned out to be a factory (non greasable) lower ball joint and it drove me nuts. The appeared fine, but were dried out under the boot. I replaced both side and havent' had the noise again.
-Greg
Inside every older person is a younger person wondering, 'What the heck happened?'
-Larry
smokum is offline
post #9 of 9 (permalink) Old 03-15-2010, 05:53 PM
I have a clunk noise issue with the front end in my truck. I know exactly what it is, the spring on the pass. side doesn't quite sit right on the axle seat. Every so often it pops and the sound reverberates through the frame making it sound worse than it really is. All I need to do is replace a washer but I haven't got to it yet.
NEED HELP: 2007 F150 will not turn over Fordxlr8r F-150 2004 to 2008 Forum 4 06-23-2009 12:15 AM
How I turn Night into Day Bush_aholic Super Duty Forum 13 04-25-2009 05:23 PM
Clunking in steering column! Chienlaid Ranger Forum 8 04-11-2009 11:29 AM
Left Turn Signal on When breaking PMarch Ranger Forum 23 12-28-2007 03:40 PM
My Turn!!! Fordxfour New Members Introductions 6 11-09-2007 10:31 PM
