98 stx 8.8 rear end - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 05-14-2010, 09:26 AM Thread Starter
Bruicer's Avatar
98 stx 8.8 rear end
my 98 f150 stx has 3.55 gears that need repaired as the pinion bearing went and is chewing up my gears can i swap them with 3.73 gears and pinion as a friend has a set of new ones for 50$ and if i can what would be the difference between them thanks.
Bruicer is offline
post #2 of 2 (permalink) Old 05-14-2010, 02:56 PM
if it's a 4x2 no problem,you'll just have to recalibrate for the speedo,if 4x4 you'll haveto change front and rear.
Rear end 99fx4 F-150 1997 to 2003 /04 Heritage Forum 3 11-18-2009 12:23 AM
Rear End Leaking :( funford F-150 2004 to 2008 Forum 8 09-01-2009 03:07 PM
Rear end cover? joetalon F-150 1997 to 2003 /04 Heritage Forum 4 08-21-2009 10:24 PM
Rear end fluid ?? joetalon F-150 1997 to 2003 /04 Heritage Forum 4 08-20-2009 05:48 PM
Rear end tag swackly F-150 2004 to 2008 Forum 3 01-06-2009 06:59 AM
