towing - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 5 (permalink) Old 06-09-2010, 01:12 AM Thread Starter
Mechanic
hawker250's Avatar
towing
i have a 1990 f250 with a 5 speed. if i am towing should i keep it in 4th or is OD o.k. I know with a auto tranny never put it in OD when towing. just wondering?
hawker250 is offline
post #2 of 5 (permalink) Old 06-11-2010, 03:49 PM
it shouldn't hurt anything as it's all gear to gear but will have less pulling power as it's a .75:1 ratio gear.
post #3 of 5 (permalink) Old 06-11-2010, 04:55 PM
I have an auto and I use OD when towing. I just gear down (turn OD off) when passing or at the bottom of a hill. I would do the same with a manual tranny otherwise you burn a bunch of extra fuel for nothing. Using synthetic fluid in the trans helps too.
post #4 of 5 (permalink) Old 07-14-2010, 09:35 AM
Maritime Storm's Avatar
4th gear, Ford in that generation recommended against towing in 5th. It had something to do with lubrication in the transmission and potential for overheating the engine.
Maritime Storm is offline
post #5 of 5 (permalink) Old 07-15-2010, 10:52 AM
Just for the record for anyone with an auto reading this. There is no issue with a 99+ SD towing in OD. Now if it's a 90's GM auto (700r4 I think); that's a different story.
Anyone have a towing opinion? munro200 F-150 2009 to 2014 Forum 11 02-15-2010 09:58 AM
Towing question pbeitschat F-150 2009 to 2014 Forum 6 09-20-2009 04:10 PM
Towing help Rustycan Ranger Forum 7 08-01-2009 08:17 PM
Towing cnelson09 F-150 2004 to 2008 Forum 1 05-03-2009 11:49 PM
Did some towing today. Smokefan Wheels and Tires 5 04-01-2007 12:13 PM
