NEED HELP: Transmission problem - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 6 (permalink) Old 07-30-2010, 10:27 PM Thread Starter
A few days ago I was driving home from work I noticed my truck was having troubles switching gears so when I got home I checked the fluid. It was a little low but nothing major. So I toped it off and went for a little drive then my tow haul would always start flashing on my dash. Then in a couple minutes my truck made a clunk sound and now I cant put it into any gears. I checked the fluid again and it does not smell burnt or look low. The only gear I have is park.
Most people I talked to say it sounds like an electrical problem. The truck is a 2006 automatic Superduty with 100k
quad_racer_12 is offline
post #2 of 6 (permalink) Old 08-03-2010, 02:49 PM
if the tcil was flashing best place to start would be read trans codes.
post #3 of 6 (permalink) Old 08-18-2010, 02:42 PM
so what was the outcome? popped snap ring? broken case?
05 F150 Lariat Screw.
89 LX5.0 usual mods.
ronburgundy is offline
post #4 of 6 (permalink) Old 10-30-2010, 08:51 PM
I bet its the toque converter.
swampthing is offline
post #5 of 6 (permalink) Old 05-17-2012, 07:05 PM
you can't move the shift lever when the key is in the run position?
IgnitionDelay is offline
post #6 of 6 (permalink) Old 05-17-2012, 07:21 PM
OP hasn't signed on since July 31 2010...one day exactly after starting this thread.
I'm betting he's either solved the problem, or forgotten all about it. lol
Transmission cooler line problem blueghost F-150 1997 to 2003 /04 Heritage Forum 5 06-29-2010 11:31 AM
What Transmission do you have? fordtough.ca Driveline and Transmission 34 04-04-2010 10:00 AM
Transmission shifting problem lilbruicer F-150 1997 to 2003 /04 Heritage Forum 6 11-12-2009 11:29 PM
Transmission problem lilbruicer F-150 1997 to 2003 /04 Heritage Forum 5 03-27-2009 03:03 PM
What Transmission? Disposable-Hero F-150 Pre-1997 Forum 5 01-22-2008 11:26 PM
