How to: AFE CAI install on 2004+ F150 5.4L (applies to most CAI) - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 18 (permalink) Old 04-01-2008, 07:18 PM Thread Starter
Alright lets start with the stock system.
Remove the factory air duct by pulling out and away.. It will just pop out
Disconnect the MAF sensor and Valve vent tube, as well any wiring that is clipped to the air box.. (1 @ back by vent tube and 1 @ the front near the bolts holding the air box in place)
Take out the 4 bolts holding the main air box to the intake manifold and slid off the clip hold the wiring/tube to the air box.
Gently pull up on the air box slowly to make sure nothing is still attached.
Remove the factory MAF sensor
Install MAF sensor with the supplied spacer gasket. If you kit some with spacers remember to put in the spacers for the bolts. Also make sure you pay attention to the flow direction arrow on the sensor.. (I've arrowed it in yellow)
Install air box support bracket
removing the 1 bolt hold the coolant resourir in place. then squishing the bracket inbehind it and tightening back up.
Undo the bolt for the fan shroud.. onf left side of engine
then put the airbox in place. Wedging underneath the fan shroud and putting bolt back in
Once in place.. Under the wiring on the left side. and put in bolts and tighten.
Install the support bracket to hold up the air intake tube. Use supplied bolts.
First install the coupler on the throttle body, placing the smaller end down.
Make sure to put the nut for the clamp easily accessable to tighten.
Tighten down to throttle body clamp first.
Slid the other 3 clamps onto the plastic tube.. Make sure the nuts are easily accessable to tighten. then the straight coupler on to the air box or tube.
Then put air tube into place, sliding all 3 clamps into place. and tighten when fully aligned as straight and least amount of stress on couplers.
Remove the whole valve cover vent tube and replace with the supplied hose.
-Then install the filter.. (Check to see if it comes preoiled from the manufacturer)
-Install the 2 bolts from the support bracket to the intake tube to hold from viberating.
-Also plug in the MAF sensor
Then go over all the bolts to make sure everything is tight.
Here's a couple vids for everyone's enjoyment!
Don't really notice it just revving up..
But sure do when your driving!!
Revving in driveway
Take off from stop
Onramp to 401
post #2 of 18 (permalink) Old 04-01-2008, 08:28 PM
1white08fx2's Avatar
Awesome step by step.Looks good too.
I never noticed that the 3V 5.4's throttle body sat right directly on top of the intake.Intersting.
How long would this install take?
stripped,slammed,& cammed!
aka 1LOW03GT
1white08fx2 is offline
post #3 of 18 (permalink) Old 04-01-2008, 08:37 PM
Smokefan's Avatar
Looks/sounds good, too bad this wouldn't work on mine
2011 Chevrolet Camaro RS2SS
2007 Pontiac Grand Prix GXP
2007 Ford Crown Victoria P71
Smokefan is offline
post #4 of 18 (permalink) Old 04-01-2008, 08:39 PM Thread Starter
Depends on your mechanical knowledge.. but roughly an hour.. Not too bad actually..
post #5 of 18 (permalink) Old 04-01-2008, 08:57 PM
Is the filter similar to the K&N,meanning that is it oil protected to stop the dirt/dust?
What kit is that?Looks like a nice piece.
aka 1LOW03GT
post #6 of 18 (permalink) Old 04-01-2008, 09:07 PM Thread Starter
Yup it comes pre-oiled.. just like the k&n setup
It is made by aFe http://www.afefilters.com/
post #7 of 18 (permalink) Old 04-01-2008, 09:47 PM
Cool,again....they are pretty nice looking set up!!
aka 1LOW03GT
post #8 of 18 (permalink) Old 04-01-2008, 09:49 PM Thread Starter
Thanks Jay!
I'll let you see it if you wanna come to woodstock.
post #9 of 18 (permalink) Old 04-01-2008, 10:08 PM
truckpilot's Avatar
Thanks for the step by step, couldn't have come at a better time, mine to be installed soon.
truckpilot is offline
post #10 of 18 (permalink) Old 04-01-2008, 10:12 PM
just dont hook up the mas air sensor backwards.... or your truck will run backwards !!
CAI can you use it with out a tune? fordtough.ca Intake, Exhaust 11 08-05-2008 09:19 AM
4.2L CAI Install Smokefan Sticky Tech/How to Section 13 04-25-2008 11:23 PM
CAI and Programmer coggerwayne Alberta 6 04-23-2008 08:04 PM
CAI Smokefan Intake, Exhaust 28 05-28-2007 06:06 AM
