Some Ford Part Numbers - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 1 (permalink) Old 08-01-2008, 12:44 AM Thread Starter
Improved head gasket
3U7Z-6051-BA (Drive)
3U7Z-6051-AA (Pass)
Updated 8 thread SOHC heads (complete with valves/cams)
All SOHC models
2L3Z-6049-DA (Left)
2L3Z-6049-BA (Right)
Updated 8 thread SOHC heads (bare no valves/cams)
All SOHC models
2L1Z-6049-DA (Same number for both heads)
03 5.4 block
All 5.4 models
3L1Z-6010-AA
5.4 forged steel crank
F75Z-6303-AC
Long block
2002-2003 Harley Davidson/Lightning
2L3Z-6006-AARM
Complete engine
2L3Z-6007-YA
Upper intake/blower gasket
1999-2003 Lightning/HD
XL3Z-9L437-CA
90mm MAF
2001-2003 Lightning/2002-2003 Harley Davidson
1L3F-128579-AB
Eaton M112 supercharger
1L3Z-6F066-AA
Lower intake
1L3Z-9424-CA
Throttle body spacer (Upper intake plenum)
All 5.4 Supercharged models
XL3Z-9A589-AA
Intercooler assembly
XL3Z-8K226-AA
Intercooler radiator mount
XL3Z-8C386-AA
Intercooler radiator isolator pack
XL3Z-8124-AA
Intercooler water pump
F8YZ-8501-AA
Intercooler reservoir
XL3Z-8A080-AA
Intercooler lines
1L3Z-9N491-AA
Wiring harness
1L3Z-12A581-SA
Belt support/Dampener mount
YL3Z-8B653-AA
Dampener adapter
XL3Z-6A329-AA
Tensioner assembly
1L3Z-6B209-BA
Serpentine Idler Pulley
F65Z-8678-AAA
42lb Injector
XL3Z-9F593-AA
Headlights
2002 Harley Davidson
2L3Z-13008-AA
2L3Z-13008-AB
2002 Lightning
1L3Z-13008-AC
1L3Z-13008-BB
2002 Heritage edition (no orange stripe)
3L3Z-13008-AA
3L3Z-13008-BA
Corner Lights
2001-2003 Lightning
1L3Z-13201-BA (Left)
1L3Z-13200-BA (right)
3L3Z-13201-AA (Left)
3L3Z-13200-AA (Right)
Fog Lights
YL3Z-15200-BA (left)
YL3Z-15200-AA (right)
Taillights
2001-2003 Lightning
1L3Z-13404-CA
1L3Z-13405-CA
N808956-S301 (upper bolt)
N808955-S301 (lower bolt)
3rd Brake light
2001-2003 Lightning
1L3Z-13A613-AA (Lens)
1L3Z-13A625-AA (Wiring)
Lightning Rear Sway bar
XL3Z-5A772-AA (Bar Assembly)
XL3Z-5493-AA Insulator (need 2)
XL3Z-5486-AA Rear Clamp (need 2)
XL3Z-5K484-AA Link Assembly (need 2)
N803771-S56 Bolt M10X1 (need 2)
XL3Z-5B498-AA Rear Bracket (need 2)
N620482-S2 Nut-N10-1 (need 4)
N800937-S427 Nut-M12 (need 4)
Lightning Bilstein Shocks
1L3Z-18124-AC (front)
1L3Z-18125-AA (rear)
F65Z-18197-BB (rear insulator nut, need two)
1999-2003 Lightning Bumper Cover
1L3Z-17D957-BB (cover)
YL3Z-17757C-AA (steel bumper)
1L3Z-17E857-BA (bracket)
1L3Z-17E856-BA (bracket)
XL3Z-17E856-AB (bracket)
XL3Z-17E856-AA (bracket)
2C5Z-15200-AA (Fog Light x2)
2L3Z-16720-BA (PLT Assembly)
2L3Z-16720-AA (PLT Assembly)
Flairside bed side steps
2000 Harley Davidson/1999-2003 Lightning
F65Z-8320012-AAB (right)
F65Z-8320013-AAB (left)
Flairside bed end caps
F65Z-8320013-AAA (left)
F65Z-8320012-AAA (right)
Upper Grille
3L3Z-8200-CA
Center console lid
2001 Harley Davidson
1L3Z-1606024-BHD (front)
2L3Z-1606024-AHD (rear)
2L3Z-1606024-BHD (front)
3L3Z-1606024-AAA (front)
3L3Z-1606024-BAA (rear)
PCM
2C6Z-12A650-AB
Brake fluid
Ford DOT3
C6AZ-19542-AA
Deep Transmission Pan
F81Z-7A194-BA (Pan)
YC3Z-7A098-BA (Filter)
Camber Bolts
F65Z-3B236-BB (bolt)
F65Z-3C178-AA (cam)
264-2953 (NAPA)
Goodyear Gatorback Belts
4080660--stock blower belt
4080675--blower belt with 4-6lb lower pulley
4080990--accessory drive belt
Harley Davidson bed mat
1L3Z-99112A15-DA
Bumper plug
XL3-17D754-AAB
K&N filter (stock airbox 2002-2003)
33-2140-1
Cobra water pump
YR3Z-8501-AB
6-Disc in dash
3L3T-18C815-AB
Navigator Chrome Antenna Base Cap
F85Z-18A927-AA
2001-2003 Harley Davidson key
164-R0461
Harley Davidson fender badge
3L3Z-16720-AB (2003)
2L3Z-16720-BA (2002)
Engine block heater (All Models)
XL3Z-6D008-AZ
20x9 Wheel
2000-2003 Harley Davidson
YL3Z-1007-DA
Harley Davidson SuperCrew cover w/ HD logo
YL3Z-19A412-NA
Muffler assembly
1L3Z-5230-DA
Chrome interior pieces
1L3Z-16219A64-BA (Driver door handle)
1L3Z-16219A65-BA (Pass. door handle)
YL3Z-1561737-AA (Driver seat lever)
YL3Z-1561736-AA (Pass. seat lever)
YL3Z-1562622-AA (Driver seat knob)
Lincoln Blackwood window trim
YL7Z-7821452-AB (front)
YL7Z-7821453-AB (front)
2C6Z-1625596-AAA (rear)
2C6Z-1625597-AAA (rear)
Chrome Navigator door handles
F85Z-7822404-AAF (Passenger)
F85Z-7822405-AAF (Driver)
Chrome bed tie downs
3L3Z-9900064-AA
Center caps
2L3Z-1130-BA
Exhaust tips
YL3Z-5255-AA
Chrome nerf bars
2000 Harley Davidson only
YL3Z-16450-CD (Left)
YL3Z-16450-CC (Right)
Harley Davidson bug shield
1L3Z-19C900-BA
Harley Davidson Carpet floor mats
HDF-1013086-CAC
Harley Davidson vinyl floor mats
YL3Z-1513086-AA
Harley Davidson splash guards
1L3Z-16A550-EA
Harley Davidson Molded splash gaurds
HDF-16A550-MLD
Harley Davidson wrap bra
1L3Z-19A414-FA
Harley Davidson sport bra
1L3Z-19A414-AA
Harley Davidson soft cover
HDF-99501A42-SC (2001-2003)
Pinstripes/Flames
YL3Z-1820000-1-AAA (2000 R/L)
1L3Z-1620000-1-AA (2001 R/L)
2L3Z-1620000-1-AAB (2002 DSG R/L)
2L3Z-1620000-1-AAA (2002 BLACK R/L)
3L3Z-1620000-BAA (2003 BLACK RIGHT)
3L3Z-1620001-BAA (2003 BLACK LEFT)
3L3Z-1620000-AAA (2003 TWO TONE RIGHT)
3L3Z-1620001-AAA (2003 TWO TONE LEFT)
2004 Navigator Water Pump
2000-2003 Harley Davidson/Lightning
3L3Z-8501-CA
2002-2003 Harley Davidsion Radiator Hoses
Top ----- XL 3Z-8260-AA
Bottom -- XL 3Z-8286-CA
Upper WIring Harness COP replacement connector (includes the plug to the COP and about 6" of wire)
3u2z14s411sla
Fuel PUmp Resistor
F81Z-14A601-AC
Thermostat's
Stant # 13967 170*
NAPA # 162 180*
NAPA #3 170*
Radiator Shroud Rivets
N804837-S (these hold the Radiator shroud in place)
Rear Bumper Assembly HD
part# YL3Z-17906-FA
Transmission Inspection plug
part # F65Z-6C070-AB
Relay cover
Part# XL3Z*14A099*FA
Fuse box (BJB) cover
Part # 4L3Z*14A003*AA
4x4,Navigator, Super Duty Fuel Filter
Ford Motorcraft PN FG-872.
Stock Exhaust Header Gasket,
you need four Part #YC2Z-9448-A
Fire Wall Wire Loom Cover
Part # 2L1Z78021A36AA
02/03 Radiator Shroud
Part# XL3Z-8146-AA
Wheel Bearings and Seals
Front Wheel Bearing (inner):
Part #F65Z1201AA
Front Wheel Bearing (outer):
Part #F65Z1216AA
Inner Wheel Seal:
Part #E6TZ1S190A
Lightning '02
LH Turn Signal Assembly: 1L3Z-13201-BA
RH Turn Singal Assembly: 1L3Z-13200-BA
fog light assy. YL3Z15200BA
Lincoln Navigator Chrome Antenna Base Cap:
F85Z-18A927-AA
2003 HDF-150 Keys. 164-R0461
2003 HD-F150 Emblems:
3L3Z-16720-AB
_
Oreo is offline
What part of Quebec are you from? fordtough.ca Québec 10 11-19-2013 08:47 PM
Place To Find Truck Part LaredoRV Truck/SUV Talk 6 01-03-2009 06:53 PM
