NEED HELP: AC/heater control problems - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 3 (permalink) Old 10-02-2011, 05:18 PM Thread Starter
On my 98 truck I have ben having issues for a couple of years and been meaning to ask and never do until now!!!!
My issue is with the nob that control temp cold to hot and I really need to work with to make it actually work or get the proper temp in the cab and just wondeirng of ANYONE knows what my problem is and can it bne fixed!!!!!!
THANKS
post #2 of 3 (permalink) Old 10-03-2011, 08:46 AM
Your blend door sounds like it may not be working. Check fuse #5 under the dash, by checking to see if the daytime running lights are working, since they run off the same fuse.
post #3 of 3 (permalink) Old 10-04-2011, 11:23 AM Thread Starter
Between me and my brother thinks its the knob or maybe shft because I really need to work with it to get heat or cold air to work... JUst not sure if it is the knob or the shaft for the knob!!!!
AC heater knobs maplesyrup Interior 0 12-03-2010 05:37 PM
Heater problem RedFlareside4X4 F-150 1997 to 2003 /04 Heritage Forum 14 11-11-2010 03:13 PM
Heater/AC controls stormy663 F-150 1997 to 2003 /04 Heritage Forum 7 09-03-2010 10:53 PM
BLOCK HEATER MississaugaRanger Ranger Forum 30 03-07-2009 12:28 AM
Heater Help BigDawg99 Interior 8 11-08-2008 08:17 AM
