Flasher Relay - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 10 (permalink) Old 06-20-2012, 06:40 PM Thread Starter
Dank_44's Avatar
Flasher Relay
I installed new tail lights and put L.E.D bulbs in. Long story short, I found out that I need to put a new relay in to fix my fast flashing. Went to put the new LED relay in and all I get is chatter/buzz now. Is the new relay shot?
Dank_44 is offline
post #2 of 10 (permalink) Old 06-20-2012, 08:57 PM
Do the lights have resistors on the LED bulbs if not that is most likely your problem
post #3 of 10 (permalink) Old 06-20-2012, 09:49 PM Thread Starter
Dank_44's Avatar
No resistors but from what I've read a new LED flasher will fix the problem without having to use them. Im thinking the new relay isn't good because of the buzzing it makes once I plug it in.
http://www.ebay.com/itm/LED-bulb-tur...-/360409874759
Dank_44 is offline
post #4 of 10 (permalink) Old 06-20-2012, 10:14 PM
I think SKRWZ is on the right track. Even though it's an "electronic" flasher, going by the bottom diagram on your e-bay link, it probably still needs some resistance in the circuit to operate properly. An LED by itself basically looks like a dead short to the circuit. It has no internal current-limiting, so you may need to add some resistors in series.
post #5 of 10 (permalink) Old 06-20-2012, 11:14 PM
I've never used those LED flasher's so I cant say but I have used resistors in the past with great success
check out this place for LED's flashers, and resistors good guy to deal with http://www.superbrightleds.com/cgi-b...rake-turn.html
post #6 of 10 (permalink) Old 06-21-2012, 10:17 AM
Usually if it's a good led flasher you wont need to add a resistor to the circuit. I know lots of guys that build their own led lighting that don't use resistors. Just a led flasher.
Might be the pinout doesn't match the vehicle and it's being wired wrong.
post #7 of 10 (permalink) Old 06-21-2012, 06:24 PM
Yeah, but on this one, if you look at the schematic on the ebay link, it looks like it assumes the LEDs each have a resistor. Not clear if this is mandatory for this unit, but I'd assume it is.
Easiest way to find out is splice in a resistor and see if it works.
post #8 of 10 (permalink) Old 06-21-2012, 09:15 PM Thread Starter
Dank_44's Avatar
I didnt use the one from the ebay link. Just showing you guys what I mean. Also what do you think cause the buzz/chatter I'm getting from the new one being plugged in? As for resistors I rerally dont want to be bothered with them. Thanks for the SKRWZ.
Dank_44 is offline
post #9 of 10 (permalink) Old 01-03-2013, 12:46 PM
Where is the relay flasher in the 97-03. I can't find the old to put the new in.
post #10 of 10 (permalink) Old 01-03-2013, 06:22 PM Thread Starter
Dank_44's Avatar
Underneath the dash and right of the steering column (pretty much behind radio and down) Its a black box. I had the flashers going to make it easier to find.
Just a heads up, its a bitch to get at, especially being 6'4 290.
Dank_44 is offline
Mirrors reflectors to LED flasher Mod BluXTR10 F-150 2009 to 2014 Forum 1 03-04-2011 06:44 AM
Flasher not flashing Fordwheeler Exterior 7 11-11-2010 09:09 PM
2009 Ranger FX4 - DRL Relay transplanted Audio and Electronics 8 01-29-2010 03:54 PM
Auxillary Relay Box Haley-Special F-150 1997 to 2003 /04 Heritage Forum 1 10-02-2009 03:54 PM
How to wire a Fog/ Driving light relay SKRWZ Sticky Tech/How to Section 2 09-26-2008 02:32 PM
