NEED HELP: Fuse type indentification - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 4 (permalink) Old 07-23-2015, 01:57 AM Thread Starter
Does anyone know what type of fuses are in the fuse block that is located at the bottom left of the dash. The access panel is between the e-brake release and the hood release.
My issue is that when the truck is running and I turn on the headlights I get no cluster illumination, no radio button lights and no climate control lights. All trouble lights etc.. on the dash work. The weird thing is, once I turn on the headlights I can put the switch to the OFF position and the headlights stay on. I turn off the ignition and the headlights stay on. The only way to get the headlights to turn off at this point is to press the keyless entry buttons 7-8 and 9-0 at the same time to lock the doors.
I know the fuses I need to check on that fuse block are F2.2 and F2.16 but I have no idea if they are minis or micro connectors and the only way to know is to remove the fuse block and I'd rather just remove it once rather than twice.
For now I have a small set of 2 LED mood lights plugged into the power port stuck to the top of the steering column so I can see my cluster at night.
Any info is helpful.
post #2 of 4 (permalink) Old 07-23-2015, 03:54 AM
I like Fords Too's Avatar
with issues like those I might wanna pop the headlight / dimmer switches outta tyhe dash and give em a quick sniff test
if they smell burnt you probably need a new switch
and that would likely kill fuses
as for what they call the half sized fuses in our trucks Idono
but a 20 amp one is 6 bucks at the dealer
crappy tire wanted 6 bucks for ones that glow when burnt and 5 bucks for a few that don't glow
they're half the size of the fuses found in say an 80's car - the flat plastic ones
I like Fords Too is offline
post #3 of 4 (permalink) Old 07-24-2015, 09:28 PM Thread Starter
Answer = Mini.
I got an assorted pack for $8 at parts source, had 8 differnent ones. I swapped out the 5A and 20A and it didn't fix it. At this point I may take out the cluster to check for loose connections. If thats all good I'll check the light switch and if that fails I try to remove the fuse box to see if its got corrosion. After that I give up and take it to the shop.
Every thing works on the light switch, interior light, marker lights, fog lights, just once you turn it on with the motor running you can't turn the headlights off without locking the doors with the remote or keyless enty buttons on the door.
post #4 of 4 (permalink) Old 08-07-2015, 01:36 AM Thread Starter
Well swapping fuses didn't fix it. Checked the connections on the back of the cluster. After that I lost all my marker lights. Took it to my mechanic, turns out the issue was a loose wire connection from the fuse box under the hood that runs to the interior fuses. Issue solved.
Fuse panel T_RAT F-150 2004 to 2008 Forum 3 02-04-2013 11:04 AM
12V Plug Fuse Location: 2008 F150 LaredoRV Audio and Electronics 5 11-07-2008 08:22 PM
NEED HELP: LOUD vibration type noise RichmondRanger Ranger Forum 6 10-11-2008 10:52 AM
Fuse between Dome lights William Young Ranger Forum 3 06-03-2008 09:53 PM
