NEED HELP: 2004 f150 windows wont go down, - FordTough.ca - Home of Canadian Ford Truck Enthusiasts
post #1 of 2 (permalink) Old 09-18-2008, 08:43 PM Thread Starter
so i guess im lucky they wont go down,,, because having them down and not going up would be worse!
anyways, i am thinking the the problem is in the wiring between the truck and the door of the truck where they go threw the rubber cover thingy,,, beucase last week my door chime would go till my door hit a certain point and then would stop,, and when i would do up my windows last week it wouldt work with the door all the way open, now nothing works,, i cant open my passenger window or the rears from the drivers seat or at the controls at each door,, im thinking that whatever wire is broken,, broke when the window lockout switch was turned on,,
so is there any instruction on taking the door panel off? or does anyone have any other related troubles like this? that maybe is easier than what i think is wrong? anyways,, thanks in advance!!
04fx4 is offline
post #2 of 2 (permalink) Old 09-18-2008, 08:49 PM
im not 100% sure but there are screws in the door probly around the armrest area then the door panel should slide up it will be stiff it will have multiple plugs that hold the panel on they do make a tool for removing them (not sure for the newest trucks) but most times you can get them without
as for the wiring could it be a loose plug either from the switches or under the dash and everytime you open your door it pulls on the wireing.... just an idea
NEED HELP: 2004 F150 Heater Problem BigDawg99 Interior 11 12-19-2009 08:38 AM
How to: AFE CAI install on 2004+ F150 5.4L (applies to most CAI) Viper238 Sticky Tech/How to Section 17 08-20-2009 11:30 PM
2004 F150 kwy290 New Members Introductions 11 02-06-2008 12:20 PM
